Previous in Forum: Sheet Cutting Software: Looking for Suggestions   Next in Forum: PPE
Poper Way to Dress Diamond Wheel
01/15/2008 2:51 AM
Has anybody from toolmaking or surface grinder, knows and can share the knowledge of the correct and proper way of dressing diamond wheels or CBN wheels used for grinding carbides?
"Necessity...... is the Mother of Invention"
Re: Poper Way to Dress Diamond Wheel
01/15/2008 4:28 AM
Yes. It's a skilled task that must be entrusted to someone who has been trained and assessed as Competent, for safety and indemnity reasons.
01/15/2008 9:17 AM
Hi Reytek...shown below is a link that helps answer your question...if you still have problems I can put you in touch with people who are skilled in dressing diamond wheels.
http://www.cnczone.com/forums/showthread.php?t=7496
01/15/2008 12:15 PM
U CAN USE DIAMOND DRESSERS FOR DRESSING THE WHEELS. DIAMOND TOOLS LIMITED FARIDABAD MANUFACTURES DIAMOND DRESSERS
01/16/2008 7:44 AM
Dressing sticks made from silicon carbide or alumina oxide (soft bond) are usually used for dressing diamond tools.
Diamond Tools must be used with diamonds exposed properly through frequent dressing. Otherwise, the diamond tool will glaze over. They will begin to tear rather than grind which is very destructive. Tearing caused from unexposed diamonds creates friction. This causes uneven wear and heat cracks in the diamond tool as well as material being machined. Resulting in premature diamond tool wear, blade tensioning problems, and will eventually destroy the diamond tool. The more a diamond tool is dress the cooler it will drill or cut
See http://www.ukam.com/dressing_sticks.htm for more info
D.
Register to Reply 4 comments
carbidedrills (1); DGCYS (1); gauravgulati (1); PWSlack (1)
