Previous in Forum: Meteorite or UFO?   Next in Forum: Leaking Oilpan
Modeling PV Cells
01/16/2008 9:24 AM
Hello. I have been charged with the task of creating a basic model which can predict power output of a common silicon based photovoltaic cell as it relates to changes in the epi layer (defects, thickness, % coverage, etc). I'm not exactly sure what equations to use or where to even start. Could anyone point me in the right direction? How much harder is it to add in doping to the model?
Thanks
Avery montembeault
Re: Modeling PV Cells
01/16/2008 1:32 PM
Suggest you type 'PV cell model' into Google ..it worked for me in about 5 secs
Too many links to direct you to, The first hit had more maths than this cat would like to use....
I'm sure you will find many models of varying complexity...
01/17/2008 10:41 AM
In your favorite SPICE (i use LTspice),
modify a rectifier diode (4001 for instance) to greatly increase "Is" to like 1E-4.
Adjust this as necessary to match the output voltage.
Connect a current source in parallel to match the photo current.
Max output power occurs when loading causes the voltage to drop just before constant current mode.
PV cells are nothing magical, just diodes like any other,
Ditto for LEDs.
alzie
01/17/2008 1:13 PM
Plastice works fine too
