I was out in the country again yesterday. After completing my work (in 31degree sun) we were sitting chatting in the shade of a big tree. The conversation eventually involved the Vredefort meteorite impact and he said he had something to show me.
He bought the property with an existing house 25 year ago. (From the design I would guess it was built in the 1950's ) The corner of the house were sinking (dolomite) and he had a trench dug next to the house. He went to a distance below the foundation and jacked the foundation up and concrete fill the cavity.
He found the object about 2m below the surface. The object is 180 x 130 x 110 mm and gave the impression that it was broken off the corner of a bigger 110 mm slab. The top and bottom is rather flat 2 off the sides are also almost flat and square. The weight is 11kg.
The Object is almost pure chrome with signs that it was exposed to heat.
Embed in the top seems to be a black glass like substance. 8 to 10mm wide (Tapering slightly) and 60 mm long, flush with the surface. At the top of that orientated at 90 degrees to the first is a 15 cm long x 10mm diam. substance dark brown in color and even more glass like in appearance. (like a piece of 10mm branch that was turned into stone). There is even a difference between the inside and outside like a growth ring)
On the bottom irregular ripples is visible (almost equivalent to the water trapped in the corner of a side window when traveling at a speed).
The brown and black substance were apparently confirmed to be Tektite. (and looking at wiki I have to agree – The only difference is that it is embedded in the chrome).
He theory is that the force of the impact caused the Tektite to form and the object was thrown up into space and dropped 175 km further. The direction is however 70 degrees to my estimate of the direction of the impact.
My questions
1) Was the object really molten when it hits the earth?
2) Can a blop of chrome (molten or not) break up into regular shaped pieces?
3) What do CR4 think about the jumping /reflected pieces.
4) Are there any more examples of tektite embedded in metal.
5) Given the regular shape of the piece, what about it being ripped out of a floor or panel of a UFO?
