Previous in Forum: Structures and HV lines   Next in Forum: Current-controlled PWM inverters in drive systems with brushless dc motor
currrent rating of cable.
01/17/2008 4:01 AM
what is actuall relation between SQ MM of power cable on its current rating ?
User-tagged by 1 user
Re: currrent rating of cable.
01/17/2008 4:06 AM
The latest edition of the Institution of Electrical Engineers' "Wiring Regulations" can provide a comprehensive insight into this question.
Good Answers: 143
01/17/2008 7:49 AM
This question comes up a lot.
There is not an equation that tells you a relation. The answer depends on the type of insulation, frequency of the power, whether it is in conduit or not, number of cables together, etc. You MUST use a table such as the one named by PW or the NEC or whatever. Wherever you live, there is an electrical code that tells you the answer. Ask an electrician.
Register to Reply 2 comments
You might be interested in: Cable Laying Services, Cable Assemblies, Cable Trays
