Previous in Forum: how profitable the synthesis of the ethanol is starting from the ethylene?   Next in Forum: Preparation of cobalt(III)-EDTA complex without a catalyst? st
13 comments
Need pump for sulphuric acid!
01/20/2008 5:36 AM
Dear all
I need pump for sulphuric acid ( 98%, T > 700 oC). Could you please introduce to me some suppliers ?? Thanks you very much! email: hoantran0712@gmail.com
Hoantran
Re: Need pump for sulphuric acid!
01/20/2008 8:45 AM
contact your local chemical supplier if you could not find on here at GlobalSpec.
They will either have one or direct you to one. Where are you?
01/20/2008 10:37 AM
700 degree Centigrade? 98%-is it final?
H2SO4 would have long back been dissociated to H2O and SO3 and caused havoc-corroding everything.
Come down in Temp--and there will be easy solutions.
Continuous--or batch-- if so how often?
From what reservoir?Is it pressurizable? How fast do you want to lift the batch?
To what height do you want to lift?
01/20/2008 8:36 PM
Dear All
a mistake, temp is >= 70 degree C not 700 oC, Sorry! I'm In Viet Nam. I need it for a metallurgy factory. Please let me know some suppliers (EU or US). Thanks to all
Hoantran
01/21/2008 1:26 AM
Hi hoantran,
I am Vietnamese too, where are you ? I am living HCM.
If you are in HCM too, please email me for your need.
Nature is unlimited, human's knowledge is limited
01/21/2008 1:30 AM
are you selling these kinds of pump in Vietnam ?????
01/21/2008 2:46 AM
No but I know where to sell it.
Good Answers: 58
01/21/2008 3:20 AM
Try Goulds pumps (www.gouldspumps.com) for their non metallic designs or Lewis Pumps (part of the Weir pump group).
01/21/2008 3:48 AM
A company totally focussed on highly corrosion resistant centrifugal pumps and valves is Richter Chemie-Technik, Germany, www.richter-ct.com.
Broad range of Teflon-lined magnetic drive and mechanical seal pumps as well as of shut-off, control and safety valves. Not cheap, but really good quality.
Regards
Manfred
01/21/2008 3:50 AM
<....T > 700 oC...>
Wow! It's going to be one hell of a pump.
01/21/2008 3:52 AM
Concentrated sulphuric acid in not a problem to handle.
However, the choice of pump will depend upon the operating parameters and the site conditions.Specify the capacity ( discharge rate im m3/hr or GPM or any other unit)
and the pressure/head as well as suction conditions.The purpose for which is required : transfer,dosing for a process etc.
Choice could be a simple cast Iron centrifugal pump with Mechanical seal ( Viton,Tc and C) to High silica cast iron pump or Poly propylene or even solid teflon.There are costlier alloy pumps as alternative.If the capacity is small and the heads are high you may have to select a diaphragm pump or special rotary pumps.
Cowlagi
Colfax Group
Tushaco Pumps,India
Canada - Member - New Member
Good Answers: 11
01/21/2008 5:29 AM
I agree completely, the flow specifications make quite a difference in the choice of a pump. A very very wide market.
I used perilstaltic with viton tubing and teflon solenoid piston pumps for 10M sulphuric acid at room temperature. Works well if you need ml or µl control.
If you need to control the PH of a process bath, perilstatic may be applicable in your industry.
01/21/2008 5:11 PM
Check out March Pumps. Magnetically couples no seal failure to worry about
01/21/2008 9:04 PM
I agree ... mag pump is the way to go
Register to Reply 13 comments
Anonymous Poster (3); cowlagi (1); gigaconcept.com (1); hoantran0712 (1); Manfred (1); MUKULMAHANT (1); nam70 (2); PWSlack (1); TexasCharley (1); The Prof (1)
