Previous in Forum: API 650 TANK   Next in Forum: Glass Fiber Reinforced Polypropylene Pellets
Gold Mine Crushers
01/22/2008 5:45 AM
whats the best maitenance for crushers, chutes, pulleys, counter weights and conveyor belts?
Re: Gold Mine Crushers
01/22/2008 6:29 AM
As 'prevention' is better than 'cure', how does this concept relate to current practice?
Good Answers: 15
01/22/2008 8:03 AM
Don't you have any manuals for this equipment?
If you have manuals do they give a maintenance schedule?
decades + ago when I worked for a company that supplied items such as crushers and conveyors I had to gather information to be put in the manuals that were sent to every customer.
Have you contacted the original equipment manufacturer? There could be a tag on the equipment with serial # and other useful information.
downhill slide to 112 (damn memor.)
Good Answers: 38
01/22/2008 11:46 AM
After contacting the manufacturer for Preventive maintenance schedules, monitor the equipment to see if any particular parts are failing sooner than expected. Adjust the frequencies to correct for whatever is needed. Such as lubrication, cleaning, adjusting etc. If contamination is a possible cause, look to shield the parts that are affected or step up routine cleaning. Bearing failure can usually be attributed to poor greasing schedules. Counter weights with cams should be greased well. If they are cable mounted, inspection of cables for wear and greasing of pulleys aligning cables are a must. Chutes, depending on the type of material being handled, can be coated to facilitate reduction of friction or to protect from wear.
The last fight was my fault. My wife asked "What's on the TV?" I said "Dust!"
01/22/2008 6:23 PM
Good house keeping, good history, and manufactures recommendations, and your own personal experience.
Regards JD.
04/16/2009 9:07 PM
Dear all,
our company is a professional manufacturer of mining crushers and industrial grinding mills company from China,our main products include jaw crusher,cone crusher,impact crusher,vsi crusher,vibrating screen,stone crushing plant,etc.our website:http://www.mineral-grinder.com Now in order to make our products develop in foreign country,we want to recruit the foreign agent,our requirement is the following:
(I):Should know the technology of our products.
(ii)should be sincerely
I you have the above condition and want to cooperate with us,please contact with us: sunnyzhang927@gmail.com
Anonymous Poster (1); charsley99 (1); ddk (1); jdretired (1); PWSlack (1)
