Try a supplement called of New Forward, also by the craving you are needing folic acid, potassium , magnesium. Talk to your doctor, they should be able to give you the best supplement and proper dosage.
The more complex the mind, the greater the need for the simplicity of play... If you think you can or think you can't you'll always be right
