Previous in Forum: Modular Switches   Next in Forum: Stepper or Servo?
load flow
01/24/2008 3:52 AM
can anybody explain, what is load flow?
how to analize a load flow in a plant?
Good Answers: 61
Re: load flow
01/24/2008 12:12 PM
Load flow is the transfer of real (watts) and reactive (VARS) power from source to load. To analyze it you need information on the source, the loads, and the conductors between the two. If the plant is already operational, you can measure the load parameters (KW, KVAR, current, voltage). If this is a proposed facility, you must make an educated guess based upon the ratings of the equipment and the expected operating conditions. For the conductors, you need impedance values for each circuit.
The analysis can be performed by hand, but it is very tedious and repetitive. There are many companies which offer software to perform load flow analysis, such as EasyPower, EDSA and SKM, among others. (This is not an endorsement of any particular package. I found these with a simple Google search.)
Re: load flow
01/26/2008 1:21 AM
Hi,
The load flow is the backbone of the power system operation, analysis and design. It is necessary for planning, operation, economic scheduling and exchange power between utilities. The power flow is also required for many other applications such as short-circuit calculations, transient stability and contingency analysis. The results of load flow are uaed to defined the power flow (P-kW and Q-kvar) magnitude and direction on each line and the losses in the lines in order to defined the required generation that satisfy the power balance condition (Generation = Load + Losses).
The goal of Load flow problem is to defined four variables on each bus, Voltage magnitude, voltage angle, net active power (P) and net reactive power (Q). There are two power flow equations can be written for each bus. The power flow solution is to solve these equations for values of unknown voltages that satisfy the power balance condition at each bus. These non-linear equations are known as power flow equations or load flow equations and must be solved by iterative techniques.
Re: load flow
07/02/2024 8:42 AM
Anonymous Poster (1); pwr2thepeople (1); PWSlack (1)
