When looking at the drawing of generator field wiring slot, I see "creepage block" between coil wedge and the coil. I suppose, its purpose is to create ventilation passage for the coil. Why is it called "creepage"?
Creepage is the shortest distance ALONG THE SURFACE of an insulator between two conductors at differing potentials. Creepage distance is important in order to prevent surface tracking due to breakdown from moisture, dirt, etc. Frequently, designers will even put blocks that look like corrugations in to make that distance as long as possible. Excuse my caps use; my italics button isn't working.
Further to TVP45, minimum creepage distances are specified in the construction and design standards to which the equipment is built. The higher the voltage in the equipment, the larger the creepage dimension will be. I guess they chose "creepage" since electrical arcs appear to "creep" across a surface between two conductors.
Either that or the fellow who coined the term was named Harry Creep (just kidding!)
