Previous in Forum: Types of Silicone Rubber   Next in Forum: Plastic For Explosion prone areas
13 comments
Paste Filler That Can Withstand 720F?
01/24/2008 3:58 PM
Can anyone refer me a paste grade (filler) product that will bond well with most metal substrates and will not be affected by temperatures a bit over 720F?
I know chemical contact will not be an issue here, and neither would abrasion, but I am aware that epoxies will carbonize over 500F, and I have a need to apply a paste grade filler material in different areas. I imagine an inorganic nature is necessary.
Thanks in advance!
Good Answers: 143
Re: Paste Filler That Can Withstand 720F?
01/24/2008 4:16 PM
Without knowing your exact application, I can suggest you look at Sauereisen Cements.
www.sauereisen.com
You might have to give them a call to check on exact properties, but I've used them over 2000F.
01/24/2008 4:31 PM
Not sure about inorganics, but you are certainly right about the epoxy limits.
I have heard in the industry that Silicates would be your best choice, but I have no clue as to what product would serve you.
Good Luck!
01/24/2008 11:20 PM
sodium silicate's are used as "Stove Cement"
Commonly used around wood stoves to seal the joints, in cast fireplaces. And also to fix oil stove combustion chambers"Glory holes". Available from many building supply, and especially fireplace stores. The finer grades work the best, in my experience, you can use glass matting, with it also, years ago Asbestos matting was used. Sodium silicate, is also used in many slug baits --- works to seal very fine cracks.
01/25/2008 4:00 AM
Try using 'Hi-Temp LAB-METAL' www.AlvinProducts.com o.k. for temperatures upto 1000F
01/25/2008 4:42 AM
How about fire cement? It is used to join bricks used in refractory furnaces.
In the UK, the heritage railway sector uses loads of it when replacing and repairing brick arches in locomotive fireboxes.
01/26/2008 6:00 AM
Fireclay Putty- Simplest and readily available.
01/25/2008 6:49 AM
You might check JB Weld. I know it works well on cast iron exhaust headers and they can get hot enough to glow red.
01/25/2008 12:20 PM
J-B WELD is warranted to 600F according to the packaging that comes with it.
I have used it on engine blocks at the exhaust port where the temp was above this with no issues. I guess usage of it would depend on vibration and flex in your usage.
01/25/2008 7:07 AM
A lot would depend on the end use. Does it vibrate? is it mobile or get banged around? a lot of cements will crumble or fall out if subjected to these. Please explain the enviroment this will be used in.
01/25/2008 7:15 AM
JB weild will work I've used it to fill seal wear on shafts and then pwht to about 1150 deg.
01/25/2008 8:40 AM
Try Litharge and Glycerin makes an almost permanent high temp bond has been used on threaded pipe joints for a long time.
Good Answers: 18
01/25/2008 3:17 PM
I would suspect that most ceramics could work as a binder. Perhaps even fireclays.
United States - Member - New Member Popular Science - Weaponology - New Member Technical Fields - Technical Writing - New Member
01/25/2008 3:32 PM
You should talk to the guys at Henkel. They have all sorts of high temp goo
agua_doc (1); Anonymous Poster (2); DGCYS (1); garth (1); jrpeck (1); MUKULMAHANT (1); PWSlack (1); rdavis (1); robert_cameron_jr (1); silvCrow (1); TVP45 (1); Vandarye (1)
