Previous in Forum: HRW Unit- HVAC system   Next in Forum: Pressure Test of Relief Valve Body
What shall be Min. Wall Thickness in ERW Pipes?
01/25/2008 5:14 AM
Hi!
I have registered myself today itself as on 25th Jan2008. I am in India . I need to Know Min. Wall thickness can be consider safe in a ERW/CW pipe bearing /oilseal fitting area having outer dia.70mm ,in application of Axle tube of a three wheel Bike.
Re: What shall be Min. Wall Thickness in ERW Pipes?
01/25/2008 11:12 PM
1Ajay Yadav Congratulation on being registered and aboard CR4. You will find a number of knowledgeable folks here that will prove to be very helpful. You are starting off on the right foot! A good clear statement of the information you seek. One suggestion, to avoid misunderstanding abbreviations like ERW/CW spell them out in addition to the short way to be exact and clear. SS
01/26/2008 5:21 AM
1 mm is fine -if you can get.
Check with tube dealers
India - Member - Isloorkar
01/27/2008 3:48 AM
27.1.2008
1mm wall thickness on 3 wheeler axle tube? You must be nuts! Dont opinionate if u aint got the know.
01/29/2008 10:07 AM
I think 1.5 mm will be fine, do that and see how it works
02/11/2008 3:57 AM
O.k . But is there any standard or benchmarking backing this dimension? reason is i would not be able to see the perfomance for testing oint of view as Assembly will dispatched once will not come back to me.
01/28/2008 2:52 AM
Carbon steel pipe used in oil, gas and water pieline, the wall thickness has relation to diameter of pipe while manufacturing. For instance minimum diameter of pipe which could be welded is 1/8" with 1.24 mm minimum wall thicness, but the same thickness cannot be used for 12" or 20" while calculating pressure. For instance, 12" dia pipe minimum wall thickness is 3.96 mm which is Shedule 5. Similarly 20" dia, minimum wall thickness is 4.78 mm which is Schedule 5 again in this Class of pipe. Selection of thickness are made on engineering requirement and when pipe with these thicknessess are required to be manufactured under ANSI Schedule. If you are not following ANSI, on order you may use any thickness you are asked, depending upon capability of your manufacturing plant, which it can weld.
Register to Reply 6 comments
Ajay Yadav (1); Anonymous Poster (1); isloorkar (1); MUKULMAHANT (1); Stirling Stan (1); user-deleted-1100 (1)
You might be interested in: Thickness Gages, Tube Fittings, Pipe Fittings
