Dear All
As you know the relief safety valves must be calibrated periodically according technical regulations and codes. For instance the popping value is the maximum operating pressure of protected vessel.
By the other hand the regulations are specifications to perform a pressure test of valve body. What does mean? Usually the inlet flange of relief valve body pressure rate is higher than outlet relief valve body. And the pressure test for valves must be conducted at a 1.5 time more than valve flange pressure rate. How to separate this different internal spaces of this type of valve? The internal mean spring, etc. must be removed from internal space. Please suggest any possibility or provide any link to find out more information about above matter.
Best Regards to All
