Previous in Forum: Real Time Pyramid Mystery   Next in Forum: Harmonic Problem Single Phase
9 comments
Number Theory & Mysticism Part 3
01/25/2008 8:15 PM
The Golden Ratio
If a line of length x is divided into sections y and z such that x/y = y/z, the ratio of x to y or of y to z is called the golden section or golden ratio, which we will call Φ.
x
y z
The Pythagoreans had as their symbol a regular pentagon with a line drawn between vertices to produce a star. This produced 9 triangles with another regular pentagon in the center. Each line between vertices is divided into 3 sections, two long and one short. The ratio of a long line to a short line is the golden ratio. The golden ratio can be computed from the formula:
Φ = (√5 + 1)/2
An interesting property of Φ is that Φ2 = Φ + 1. Another interesting property is that 1/Φ = Φ - 1. In other words, the reciprocal of Φ is the same as the portion of Φ to the right of the decimal point. There is no other number with this property. The number sequence 0,1,1,2,3,5,8,13,21,34... is called the Fibonacci sequence after Leonardo Pisano (Leonardo of Pisa), who is sometimes called Leonardo Fibonacci. Each number in the sequence is the sum of the previous two numbers. The last number in the sequence divided by the 2nd to the last number in the sequence approaches Φ as the sequence approaches infinity. This relationship can be stated as a formula: Φn ≤ Φn-1. This information has been used in the analysis of algorithms.
More on the Fibonacci numbers in part 4. See Roger Pink's thread on The Golden Ratio in his blog on formulas.
Have any of you used this info to analyze algorithms?
S
Re: Number Theory & Mysticism Part 3
01/26/2008 11:25 AM
Thanks for the interesting chain of posts. As usual I have nothing intelligent to add, just wanted to let you I enjoy reading/learning on this topic.
As a school child I would unintentionally 'doodle' the golden triangle, buy drawing consecutively larger and larger stars. Each one surrounding the previous. I liked the way the position of the pentagon moved with each successive star
I am surprised that not 1 math teacher ever bothered to point out what I was drawing, on the borders of their test papers.
01/26/2008 11:28 PM
Thanks, Mevel. Still to come:
Fibonacci Numbers
Caculations of Π (PI)
The Uniqueness of e
The Moebius Strip
01/26/2008 11:34 PM
StandardsGuy For the next "Part 4" consider a discussion of Theo Jansen's Holy Numbers.
I think I have a book with an Egyptian math problem but without the solution. SS
01/26/2008 11:49 PM
Hi Stan,
Why not do it in this one? Find your book, and give the readers the problem. Someone surely will come up with the answer.
S
01/27/2008 2:42 PM
"Why not do it in this one? Find your book, and give the readers the problem. Someone surely will come up with the answer."
James R. Newman in Vol. I of "The World of Matematics" presents this problem of Egyptian mathematics on pages 176 - 177.
Go down I times 3, 1/2 of me is added to me, 1/5 of me is addend to me, return I, filled am I. What is the quantity saying it.
The solution IS given in Egyptian form.
What is the final numerical answer and how did you arrive at it.
01/30/2008 7:46 PM
Hi SS,
What do you mean by Egyptian mathematics, geometry? I Googled it and found links that look like ordinary math but with other numerals. I don't understand your problem. What does 'return I' mean? Looks like a computer program.
S
01/30/2008 10:36 PM
StandardsGuy The problems is/was posted exactly as it is published in the book.
Return I, filled am I, had/has me stumped too.
If I is the unknown x then 3 X + 1/3 X + 1/5 X = 3 + 8/15 X = 3.5.33333...
Now to return???and be fulfilled?????? SS
Engineering Fields - Manufacturing Engineering - New Member United States - US - Statue of Liberty - New Member
01/30/2008 10:40 AM
That was a great book- Ethan Zuckerman's musings on Africa, international development
and hacking the media. & it incorporated enough humor to keep your interest!
Vote your hope not your fear.
01/30/2008 10:50 AM
I believe that's called a Kaleidoscope .
Register to Reply 9 comments
Mevel123 (1); StandardsGuy (3); Stirling Stan (3); tubenut (2)
You might be interested in: Line-shaft Spools, Power Line Network Components
