Previous in Forum: Process Engineer   Next in Forum: ACRYLIC SINKS
13 comments
Good Answers: 25
Slippery candle wax
01/26/2008 7:46 PM
Hi all,
Could anyone help me with the mix (formula) for this substance please?
I wish to make large quantities of a "wax" with similar properties
to candle wax; i.e. formable, meltable, resistant to water, etc. while
also being slippery; similar to, e.g. a bar of soap.
My applications to the wax makers etc. have not obtained an answer;
(which is difficult to understand?) perhaps, they just don't know either!
It has to be non-toxic, as cheap as possible to make, and stable for use outdoors
(i.e it must not wash away like soap) and be impressionable. (like candle wax.)
Any ideas please?
jt.
Re: Slippery candle wax
01/26/2008 8:05 PM
stearic acid.
Keith E Bowers, PMP
01/27/2008 6:30 AM
Are you able to confide in us the application ?
Meantime, you could play with this recipe.
01/28/2008 10:09 AM
Whoops,
.........Don't recommend that: surfboard wax is to make your feet "stick" to the board, not, to make it "slip" through the water.
01/28/2008 10:18 AM
LOL ! Cheers Randall, I really should pay more attention.
01/28/2008 9:23 AM
You haven't said whether or not this product will be exposed to humans. If so, you can add a little beeswax and glycerin without making an irritating or toxic product.
Slipperiness can come from the material being "hydrophilic"...meaning it will collect a surface film of water from the air...the addition of glycerin will do this. A bit of gum arabic could help, depending on the type of wax you're using.
Slipperiness can come from a slightly softer film of a substance on the surface or it can be "intrinsic" to the materials...if it is not for human consumption, you can add a powder of very small teflon particles, or silicone.
01/28/2008 9:47 AM
Apart from possible toxicity issues, maybe have a look at hard wax polish recipes such as those for domestic old-style "quarry tiles".
01/28/2008 9:55 AM
Our Trustworthy friend from South Africa--Hendrik --can get you linked to SASOL.
They make the best F-T wax. -- all kinds-- worldwide.
Popular Science - Weaponology - Cardio-7
01/28/2008 10:37 AM
A few suggestions: Look at some of the synthetic "waxes" that are used for mold release agents in extrusion and injection molding. They are generally not water soluble. Also some silicone oils may be of interest. Fluorocarbons are likely too expensive for what you want.
Location: Somewhere in the hills of Pennsylvania, I think.
01/28/2008 1:57 PM
Think paraffin (the wax, not kerosene) and mineral oil. You heat the paraffin slowly until throughly melted, mix in the mineral oil and allow to cool in molds. Experiment with the percentages until you achieve the desired result. You might start with 10% (by volume) mineral oil.
I'm somewhere between the age of thirty-something and Alzheimer's. I just can't remember where!
Re: hello , L´m a sculptor l work with wax extensively.
01/29/2008 2:36 AM
what you want is a liqed wax , you sould call maglouthlin wax co, in L,A,they have all kinds of waxes . you say it slippery like a bar of soap, that meas soft wax, i,e, a wax with a high contactent of baby oil and reson ( like tree ) .If you could aford it use bee wax as the base wax instead of perafine. I get my wax from the cathic cenitery the use the candles once and dispose of then. I use to go to the locale recyling center and get my wax there in the used candle contaner. Hope that helps you havent said want your up to, but good luck bill busuttil in germany.
Good Answers: 25
01/29/2008 5:08 AM
Thank you all, your replies have been most helpful. Also,
Thank you Bill, (guest) Never thought of recycled wax!
(wish I could write German as good as you do English)
Many thanks
jt.
I used to be an archaeologist, but moved on, after realising my career
was in ruins.
01/29/2008 12:58 PM
You can use the low polymer wax coming out from HDPE manufacturing plant using Mitsui Technology. This low polymer has all the properties as you have described and can be used with candle wax. As this is a by product from HDPE(high density poly ethylene) plant, it is cheap also.
04/25/2008 12:48 PM
I have a lot of low polymer wax from HDPE,PP,LDPE....what can I do with it?
Register to Reply 13 comments
Anonymous Poster (3); Cardio07 (1); electromagnetic1 (1); FKIA (1); Ganga D (1); jt (1); Keith E Bowers (1); Kris (2); MUKULMAHANT (1); Randall (1)
