Previous in Forum: Carbon Black   Next in Forum: Sulfuric acid projection in RO treatment
16 comments
Good Answers: 25
heat conductive material
01/28/2008 9:39 AM
I would like to find a paint or grease that conducts heat in the 100-150F range. Is there such a thing that is relativley inexpensive? Heat source will be hot water running through PEX tubing.
Goodness has nothing to do with it.
Re: heat conductive material
01/28/2008 10:11 AM
How about DensoTape?
Good Answers: 143
01/28/2008 10:21 AM
You could go to
www.Mcmaster.com
and look at thermal grease, or you might just try heat sink grease (Newark or DigKey or probably RadioShack)
01/28/2008 10:59 AM
Try automotive engine laquer.
There's them that knows and them that just thinks they know, whitch are you? Stir the pot and see what rises up. I have catalytic properties I get a reaction going.
Good Answers: 25
01/28/2008 1:29 PM
Actually, I am trying to replace roll formed or extruded aluminum as a heat transfer medium in a hydronic heating application. I hoped maybe there was some "goop" that would do the job as well, but not have the price volatility of aluminum.
So far the leads have been interesting, but no home runs.
01/29/2008 1:56 PM
High Temp engine (auto) paint
Good Answers: 97
01/30/2008 5:55 PM
I'm thinking a compound such as terrazzo or the epoxy resins that are normally used these days as a binder for terrazzo could well provide the medium you're seeking.
Good Answers: 59
01/29/2008 4:08 PM
You do not want to do with anything that (might) have solvents in it. Such things, including greases might / will destroy the plastic PEX. I understand your concern with the extruded Alu heat exchanger.
Go to the Fine Homebuilding magazine:
www.FineHomebuilding.com
They have advertisers for subfloor heating based on crosslinked plastic (like PEX) pipes and bent Alu sheetmetal heat transfer from it to the floor, attached from below. It seems to be built just for the task you are asking about.
Just for example, see; www.radiantec.com www.warmboard.com
Good Answers: 25
01/31/2008 8:53 AM
I understand the concept of the terrazo binder or overpour of gypcrete or the like. Was hoping to avoid the need for leveling and the themal mass effect of poured concrete.
Maybe I need to go back and review my physics and heat flow. Heat sink grease seems likely, but you buy it by the ounce and I need gallons.
Good Answers: 97
01/31/2008 11:06 AM
I'm getting the idea you are not using hydronic heat on the floor?
There are heat exchangers designed for heating areas say for raising chicks or baby animals and for use in automotive application. It would be a tube with tin fins, a plethora of sizes available, www.Globalspec.com
Anyway if you are the old terrazzo binder maybe more fitting, it was a combination of poly and vinyl resins. I have used it in past to cover landings and if mixed right was self leveling though that mixture took longer to set.
You could use Lucite which is the original plexiglass but soft and easily scratched though conductive and under floor covering may suffice; available in sheet form up to 4'x8'.
Thank you for making think of this I am upgrading a century old hydronic heating system. It is conceivable to put three layers of sheeting illuminating the mill work of cutting grooves. I can use a .250" whole sheet on the wall and use strips of Lucite thick enough to shelter the PEX, fill remaining space with resin, cover with another whole sheet creating a radiant panel to replace the old time standing radiator.
Cheers!
Good Answers: 97
02/01/2008 8:51 PM
Use the mil spec # and order bulk supply of thermal grease from Standard oil.
02/01/2008 2:51 PM
I suggest using a heat sink compound that can be found in any electronic component store.
or search on GlobalSpec: "heat sink compound".
Good luck!
02/01/2008 2:55 PM
I forgot to login.
The heat sink compound is used in electronics for thermally coupling a CPU or other power component to a heat sink or cooler. I think is the right stuff for your application.
Good Answers: 59
02/01/2008 11:44 PM
You guys are off the track. The grease is designed to be used to even out heat conduction between mated metal pieces or metal to glassfiber epoxy. Neither this material can be bothered by most solvents. Any fat or solvent will attack the integrity of the PEX or any other plastic over time, causing it to rupture. So, it is not a useful idea to get near that with any of this stuff. Additionally, he needs thermal coupling by the GALLONS, and cheap. That leads back to home building techniques.
On the attack of PEX I am willing to take a small bet for bragging rights. To put some fairness into it, I am relying on long experience. I did not test this case before placing the bet offer.
Good Answers: 25
02/02/2008 10:39 AM
Leveles, you are spot on. I am trying to avoid aluminum extrusions or roll formed pieces for cost and squeek potential. Also, would like to avoid lightweight concrete if at all, due to the weight and heat sink grease sounds "not so hot".
Options are dwindling. Does anyone know if acrylic aluminum paint will conduct much heat? It is sold as a radiant barrier, but so is aluminum? So far the info off the web doesn't address heat conductivity of the paint. Think it would eventually eat away at the PEX since it has no VOCs?
Good Answers: 97
02/02/2008 12:08 PM
Inexpensive readily available good conductor of heat = table salt or the result of sulfuric acid added to salt = carbon
Glass is also good conductor of heat, beads without sharp edges from broken tempered glass.
Clay and or ceramic pastes
Quartz crystals after deburring.
Bauxite
Basalt
Bromide in solution
Good Answers: 59
02/02/2008 12:41 PM
Aluminum paint of any kind is a heat reflector for radiated heat. I have no clue, how it will behave in a conducted heat. I, for one, would leave that to the laboratories to figure out, and go with a true and tried solution in my case for now.
Register to Reply 16 comments
Anonymous Poster (2); beriberi (3); BrainWave (1); bwire (4); Hottech (1); leveles (3); PWSlack (1); TVP45 (1)
You might be interested in: Rubber Tubing, Plastic Tubing, Tubing
