Previous in Forum: heat conductive material   Next in Forum: Clinker formation in cornburning stoves
Sulfuric acid projection in RO treatment
01/28/2008 3:39 PM
Can you formulate for me the sulfuric acid usage projection for a Reverse Osmosis treatment plant with a capacity of 400 cu. meter per day potable water production with recovery of 70%. The Total dissolved solid of raw water feed is 1800 ppm having a pH of 7.4?. Sulfuric acid is used as scale inhibitor and used to maintain the feed pH to 6.4. I am working as water treatment operator curious for the design and projection of an RO treatment plant particularly in in the efficient usage of sullfuric acid. Thank you for your help.
Re: Sulfuric acid projection in RO treatment
01/29/2008 12:30 AM
What is your raw water characteristics and what sort of pretreatment do you have?
If too lengthy and need attachments you may email me direct sisiraa@gmail.com
I might be able to help you
Sisira
sisira
01/29/2008 4:13 AM
Is there a problem with BaSO4, CaSO4 and MgSO4 precipitation on the membranes? If so, it could be that H2SO4 is not the right additive, in which case the correct course of action is to discuss the matter in detail with the local water additives company representative. Let them solve the problem with some more esoteric potions with sight of a detailed water analysis, under a supply-and-monitoring contract, particularly for water that is destined to become potable.
There shouldn't be an immediate problem with the stated pH on the RO membranes themselves, as these days a wide range of pH can be tolerated. For potable water some form of re-hardening filter downstream will prove beneficial, partly to improve the taste, and partly to protect the downstream pipework components from dissolving.
Safety - Hazmat - PHA / HAZOP Facilitator Engineering Fields - Chemical Engineering - Principal Engineer Engineering Fields - Piping Design Engineering - Chemical Process Engineer
01/30/2008 4:27 PM
Many membrane manufacturers have good software that we engineers use. They are very accurate and can help to predict chemical usage, but as someone has mentioned, we would need a very detailed raw water analysis, feed temperature, flow rates, and your membrane system configuration.
I can help as well and feel free to email me at: stephan@bradleyventures.com
For examples of my work, see www.bradleyventures.com
Stephan
Do what you will whilst harming none.
01/31/2008 3:49 PM
You would use 24.5 gal. per day
Register to Reply 4 comments
Anonymous Poster (1); PWSlack (1); Sisira (1); StephanChE (1)
