We have an MCC (440V, 50 Hz) which is to feed the following:
- A packaged equipment (Water maker unit of power consumption about 55kW, 450V, 50Hz) and
- 3 motors of 12.5kW(DOL), 30kW(Star-delta), 75kW(softstarter) 440V, 50 hz
- 1 motor of 2kW (DOL) 230V, 50Hz.
So totally we have 4 feeders
Now I would like to know how do we size these feeders serving the packaged eqpt and 4 motors.. Should I take all loads as DOL and size it by checking the voltage drop or is there any difference in sizing for motor loads and packaged equipment loads?
I also understand that we need to perform a short circuit analysis or fault current analysis. Does that mean I have to get the fault current rating from the MCC supplier?
Pls let me know what I should ask the MCC supplier?
I welcome all your valuable inputs.
