Can I rewind one motor - just one of the two which work in the same electrical shaft - by using a different copper profile from the original one but assuring the same cross section?
Can I change the existing rectangular wire 3,55x1,25 mm by 6 round wires of diameter 0,95 mm?
I want to change the copper profile, because with these round wires the rewinding is too much easier to execute.
Can this solution be applied? Or, is not advisable because can change a lot the electrical data? Which special attention do I should have?
The two existing motors are exactly identical, of the same manufacturer, and work in the same electrical shaft to assure the same speed at the two motor shafts. Just one of them have the rotor burned and have to be rewounded.
