Previous in Forum: Lamp Failure Rates   Next in Forum: Types of Transformers?
False Alarm Activation
01/31/2008 11:57 AM
Does anyone know of any information or reports related to smoke alarm false alarms and humidity and or chemicals related to stripping floor finish of of floors? The background is a floor crew was scrubbing floors in a corridor that had fire doors closed on each end. While in the process of using either Stride or GP Forward to remove the top layers of floor finish. They then applied a new finish 'Vectra Floor Finish'. WE experienced a fire alarm which was linked to a smoke detector head in the corridor where the work was being completed. There have been other occurrences where smoke detector heads sent a false signal in other facilities. Is there a link and which may be the most likely cause the humidity, chemicals or the wet removal process? Has there been any studies published in this area?
Good Answers: 230
Re: False Alarm Activation
01/31/2008 11:32 PM
Hello ruro0302
Perhaps you could check out the following:
http://cr4.globalspec.com/thread/16981
http://cr4.globalspec.com/thread/17128
These appear to be Topics which should interest you, since you did start both of those Topics.
Please give other Members and Guests time to check out your Topics and answer your earlier Topics, before opening a "New Topic" with the same question as a "different Topic".
Thank you.
Kind Regards, from far away....
Popular Science - Cosmology - New Member Popular Science - Paleontology - New Member Popular Science - Weaponology - New Member Popular Science - Evolution - New Member Popular Science - Genetics - New Member Popular Science - Biology - New Member
Location: The Nevernever as much as possible, Earth when I have no choice.
Good Answers: 11
02/01/2008 1:14 AM
Dear Ruro0302: Many of the smoke detectors used in commercial buildings use what is in effect a high frequency ionization process to detect smoke particles. I the cleaner are volatile enough, the detector head will register the vapors as smoke.
B.T.W. I once had a head trigger an alarm when a large floor fan was directed towards it. The dust particles from the fan cage where blown into the ionizer head.
Dragon
Ignorance is the beginning of knowledge. Heresy is the beginning of wisdom. The ignorant heretic is the wisest of all.
Register to Reply 2 comments
