Previous in Forum: False Alarm Activation   Next in Forum: Changing the Direction of Movement for a 12 VDC Motor
20 comments
Types of Transformers?
02/01/2008 1:00 AM
What are the different type of Transformers? How can we classify them according to the ratings & what are the different type of vector connetions that are use?
Re: Types of Transformers?
02/01/2008 1:59 AM
That's not easy to answer without more details. Perhaps a Google search or Wikipedia search would get you started. Try http://en.wikipedia.org/wiki/Transformer_types as a jump off point. In general, types differ based on things like usage, construction, size, and electrical ratings.
02/01/2008 2:34 AM
Dear, as i am working in a marketing filed i also would like to know type of Transformers. As i Know
Distribution Transformers, Which is used in Distribution network
Power Transformers, which id used for change the Voltage level in transmission level.
Earthing Transformer, Which is used for control the fault network.
Generating Transformer - Which is used in generation Plant
this is my best of knowledge but i feel some other type of transformers are there but we don't know any this about that and their application if any body know about this please intimate me.
United States - Member - New Member Fans of Old Computers - PDP 11 - New Member Hobbies - HAM Radio - New Member
02/01/2008 9:10 AM
Autobots and Decepticons? (sorry, I couldn't help it. It just slipped out!)
You should try to be more specific with your question. Otherwise, its hard to answer without writing a small book on the subject.
02/02/2008 12:08 AM
How we check a faulty transformer means only one winding short priamry or secondry
02/09/2008 3:31 AM
Hi..im usually check the transformer faulty by methode winding primary short and secondary short ...Primary and secondary not to join(the cable PRIMARY and SECONDARY to open) and than test the winding by insulation test (Megger-set to 5 000 V)...Primary-Secondary, Primary-Ground and Secondary-Ground.
The result must be 1 kV = 1 M Ohm {VDE (catalogue 228/4)}, its mean if you have transformer 70 kV to 20 kV...Primary 70 000 Volt ..70 kV = 70 M Ohm (minimum),..20 000 Volt...20 kV = 20 M Ohm(minimum) there is for P-S.......... and for P/S-Ground...(Value * √3)...i hope u understand to my explanation.
02/03/2008 7:27 PM
yes..megatrons??? lol..sorry can't help it..
02/07/2008 6:00 AM
the different type of transformers that i know are as follows:
  1. power transformers
  2. distribution transformers
  3. auto transformers
  4. zig zag transformers
  5. earthing transformers
  6. current transformers
  7. voltage transformers and etc
if u people have any more type of transformers plz help me with them.
Reply Off Topic (Score 3)
02/07/2008 7:04 PM
Hi pearala.shiva,
Don't think anybody has mentioned isolation transformers. What are zig zag transformers? BTW, your comment was not off-topic.
S
07/21/2009 8:56 AM
Isolating Transformer
08/08/2012 11:46 PM
Do not know whether it helps.
But we have
audio transformers; lan transformers; planar transformers; encapsulated transformers; balun transformers;high frequency transformer;flyback transformers;IFT transformers and so on.
Why I have to dealing with transformers!!!
02/01/2008 10:56 PM
The basic principal of all transformers are same. As per rating ans use they are normally classfied. For example
1. Power Transformer
2. Pulse Transformer
3. Booster transformer
4. control transformer
According to rating in KVA with Primary and Secondary voltage you can classify for your ref ; Rating 10 MVA Primary Voltage 11000 Volts Secondary 433 Volts, Frequency 50 Hz.
I hope it is clear to u now.
Regards
C.S. PANT
02/02/2008 11:39 PM
In addition to rating, they're classified by type e.g, autotransformers (variacs) are different than transformers that provide isolation.
02/01/2008 11:56 PM
There are iron core, ferrite core (normally toroids), and air core.
Iron core are for power supplies and audio frequencies. Ferrite have different types for different frequency bands, from <1kHz well into the megahertz. Air core are for RF frequencies. You will have to be more specific on your vector question.
02/02/2008 9:45 AM
IF Transformers are a further (ancient) form used in older style radios....
02/02/2008 5:40 PM
Who remember the PARAFORMER TRANSFORMER?
02/03/2008 2:09 AM
Hi Dear,
Can you explain me please, you should not give a spoon of tea. you have to give a cup of tea
Good Answers: 40
02/04/2008 9:14 AM
A paraformer transformer is great for isolation. Whatever noise accompanies the input is eliminated, outputting only a true sine wave.
There is no shared flux ~ a paraformer acts more like a "resonant tank circuit". The biggest downside being inefficiency. Full draw on primary side regardless of how little load is connected.
Won't go any further right now... response is subject to fading memory on same
02/04/2008 9:20 AM
Very interesting discussion and I think we all continue to learn from each other. It would be helpful if the original Guest who posed the question would tell us if this has answered his/her question.
01/30/2009 1:07 AM
transformers used in smps are called /???
08/09/2012 8:53 AM
?) ... "transformers used in smps are called /???"
To WHICH "SMP" are you referring...?
Reply to Forum Thread 20 comments
Andy Germany (1); Anonymous Poster (6); C.S.PANT (1); Graebeard (2); maheshhn_07 (2); Mark Zhang (1); ndt-tom (1); pearala.shiva (1); sachin grover (1); StandardsGuy (2); Steve (2)
