Previous in Forum: Research Proposals for a PhD in Fluid Mechanics   Next in Forum: communication engineering graduation project
graduation project
02/02/2008 10:48 AM
Hi i am nader/
i am an electrical engineer specialized in(communications & electronics) undergraduate student and i am really tired from searching for a suitable creative yet -not too hard or expensive- graduation project for communication department but i couldn't so i would be very greatful for some help from you,the outcome from my studies so far ranked as this:
1-V H D L languege (for designing electronic digital chips).
2- digital communications/Digital modulation types and networking .
3- orcad (pspise) program..
4-microcontroller / microprocessors x86 & c++ programming languege/assembly language
those are the most stuff i prefere to major in and to deal with in my project
please respond, my head will explode and the dead line is near would you help me??
thank you very very much in advance..
nader
Good Answers: 42
Re: graduation project
02/18/2008 9:54 AM
Try to do a project on automatic temperature controller for automatic control of temperature of a salt bath or a furnace. Use a thermistor as a temperature sensor(transducer) a relay to switch on and off the heater and 8 bit switch to pre set temperature and 7 segment LED display for indicating the temperature.
You will need 8085 CPU , 2716 EPROM , 8212 I/O chip or 8255 PPI along with SID and SOD lines. ADC and other electronic components to assemble the microprocessor.
Do the software programming . Drawings and component values are available in any standard book on microprocessors. It will be simple and inexpensive project
Reply to Forum Thread
