Previous in Forum: Gravity Fed Holding Tank   Next in Forum: Steel Siding Engraving Machine
Aluminium Pressure Die Casting Process Problems
04/29/2006 11:25 AM
SARAVANAN writes:
Our concern is pioneer in manufacturing of Aluminium pressure die casting components meant for automobile parts, where we are facing a critical problem in thick wall casting component (35 mm thick ). Still shrinkage porosity present in 20% of components even after validating our process and settings. We need your assistance please.
Hobbies - HAM Radio - New Member Popular Science - Weaponology - New Member United States - Member - New Member Engineering Fields - Mechanical Engineering - New Member
Why such thick walls?
05/01/2006 10:57 AM
Why do you need to cast such thick walls? Reconsider your design. A criss-cross web of thinner supports will support a thinner wall, reducing pororsity AND resulting in material and cost savings. If still more strength is required, consider casting in alloy steel reinforcing parts.
Also, reconsider the alloy you are using, some have higher shrink rates than others.
Is all your porosity due solely to shrinkage (creating pockets of vacuum porosity). You may also be experiencing air pocket porosity, or porosity caused by other gases. Good venting in your die design can help. Also, Vertical diecasting machines yield lower gaseous porosity than standard Horizontal types, as released gasses will bubble up through the melt, rather than being injected into the dies.
"What, me worry?" Alfred E. Neuman
Reply to Forum Thread
