Does anyone make an amplifier that can take a variable current input and output an amplified current signal? I need to deal with a mA input that is below the sesning range of my cnnected device.
The principal answer is that a "transimpedance amplifier" can do that exactly. Look up Wikipedia about it, there is a lot to learn about, how it goes about generating a virtual ground at the input of the opamp. If you are not fussy, you can use any chip with a current mirror input (like LM2900 or 3900 a cheap older design). There your current "sees" only a diode. The output is a voltage in all cases, so you take a resistor and convert it into current, if you like.
But, That is just the beginnig. Any other circumstance unique to your situation can come back and bite you in the rear, if neglected.
Is the current about ground potential or not? Current sensing at voltage and feedback is a separate subject in power supplies.
What is the impedance of the current source?
Is the current bipolar or unipolar?
Do you need rectification at the end?
What are your bandwith / signal slope requirements?
How much and what kind of noise burden is on the signal?
You sure, you need current input on you sensing device (it is unusual)?
If I would be doing a simple setup (and if it is possible) I would prefer to convert the input current via a resistor into voltage, amplify suitably, convert it back into current via a resistor (if that is really needed).
Yeh, I did it on my graphics tablet..really rough...didn't want to show off .
I'm assuming his current sig doesn't go negative or to zero...he prob wants something off the shelf..but I just love seeing what can be done with minimum components.
hEHEHEHEHEHE .... yep I've had mine for over 6 years now and it cost a fortune... a Wacom A5 size.... you can draw what you want and put it under a flap so you just follow the drawing.... well suppoedly... I always get lost....
Now where did I leave my Paint program..... can't find it in the menus.... Hmmmmm
At last! I can now begin my collection of Unsigned Del Originals - I'll soon have the entire Art World by the short'n'curlies, clamouring at my door, begging for postcard-sized replicas.
(I'll cut you in, if you insist).
I had a little play with that freebie art software 'Gimp' (graphics Image Manipulation Pachage) even at low res (640x480) I managed this, as it gives you subtle variations of intensity. It also converst various graphics file types, so is V handy. I couldn't get to grips with 'layers' but it works well with the pressure sensitive pen.
This is the latest KrisDelTM virtual car... it's powered by a picture of a free energy PM motor. It has a picture of a stick of batteries in the boot as a backup, these are charged from a wind turbine which pops up when you hit cruising speed .
If he has a " Current Source" (with implied high source impedance) then Del's 2 resistors are also redundant. 0.7V( maybe 0.6,0.55) forward drop is o.k
The amplified current flows from the battery thru' the customers' impedance+Collector.
Find out hfe first and zero shift will be needed.
I am now looking back to 1958. Should be OK even today .
Main Entry: smart•ar•ses
Pronunciation: Get off your lazy ass, and look it up!
Function: noun
A debilitating disease characterized by the brain
losing adhesion with the inner lining of the
skull. The malady progresses as the brain is
squired by the top of the spinal column.
From there, the brain proceeds to slide down
the spine until it comes to rest and establishes
a new location in the pelvic region, somewhere
near the rectum and anus.
