Previous in Forum: Definition Requalification   Next in Forum: non conventionl energy
Tolerance (Gap) Between Mesh Jaw Coupling
02/07/2008 2:00 PM
Compliment to every member of CR4.Please,I need to know the minimum gap/tolerance space between the meshing/mating jaw coupling of 560mm diameter.If there is data table to extract value of tolrance for different sizes of jaw couplings,it will go along way in solving my problem.Thanks
Good Answers: 15
Re: Tolerance (Gap) Between Mesh Jaw Coupling
02/07/2008 2:57 PM
Try www.globalspec.com
and do a search for jaw coupling.
Then refine the search by your 560mm diameter. (Is that the bore diameter or the coupling OD diameter?)
Some of the manufacturers catalogs will include the information that you need
downhill slide to 112 (damn memor.)
02/07/2008 4:06 PM
IMPOSTER!! Or have I come back to haunt myself??
02/10/2008 8:27 AM
If you got nothing-
Go for 1º gap for the soft intermediate piece to compress.
Register to Reply 3 comments
ddk (1); Mr. Truman Brain (1); MUKULMAHANT (1)
You might be interested in: Flexible Couplings, Chuck Jaws, Turnbuckles
