Previous in Forum: Current Price of VHP Steam?   Next in Forum: What Causes Surging of Water from the Softener?
Measuring Water Content in Carbon Black-Water Mixtures
02/08/2008 7:43 AM
Are there any commercial devices for measuring water content in relatively dry mixes of carbon black powder and water.
Michael Binder
Applied Research
binder428@yahoo.com
Re: Measuring Water Content in Carbon Black-Water Mixtures
02/08/2008 10:59 AM
Yes, for most granular or powder materials that have a high melting point.
The standard way of measuring their moisture content is to place a sample on a precision weighing balance and place an infrared heater over the sample...
As the moisture is driven out of the sample the weight decreases slowly and then starts to level off as the moisture is reduced to almost zero. From the original weight and the weight loss the moisture content can esily be determined.
These moisture meters are readily available, I think they're called infrared moisture analysers or something....
Hope that helps - John.
Good Answers: 266
02/08/2008 2:09 PM
Place a sample in an oven and dry it. Cool the sample in a sealed container. Weight differences between the dried sample and an other sample should give water content.
Good Answers: 18
02/09/2008 9:48 AM
Yes, commercial devices are available, but I dont know current manufacturers.
Back in the mid 1960s, we used a device (in the food industry at Corn Products Research) that basically consisted of a heat lamp shining on a weigh scale to make the measurement. The sample was placed onhing similar could be used for carbon black. the scale and zeroed for tare. The light shown on the sample and the weight was measured automatically by weight difference when the equilibrium was reached. I assume somet
02/10/2008 6:09 AM
Humidity measurement of dry mixtures is sometimes done with simple and cheap radar equipment where the frequency is correlated to the resonance freq of H2O. Vou have two chambers, one for measurement and one for reference, both radiated by the same source. So differences in intensity are compensated by making a relational evaluation after calibrating the system with a known content of humidity.
This is used par example for determining the water contents of grain before it is milled.
Regards Uwe
The sum of intelligence on earth is a constant. And the population grows and grows and .....
02/11/2008 8:24 AM
When I worked at a steel mill, we had a moisture guage that measured the percent
moisture in the Coke (almost pure carbon) that was in a weigh hopper to determine how much coke was charged, and how much water was in there.
This guage used a nuclear source and measured the backscatter.
That was 6 years ago. I am sure they are still using this at what used to be the
Bethlehem Steel, Burns harbor plant.
02/27/2008 10:03 AM
Normally a drying scale is used; at our lab (at a carbon black manufacturing plant) we use a Mettler drying scale that uses a halogen lamp. The water content is expressed as a weight loss percentage.
See http://nl.mt.com/mt/filters/products-applications_laboratoriumwegen_halogeen-vochtanalyse/Moisture_Analyzer_0x000010083f6eb48c40005a4b.jsp (we use the left one)
08/25/2010 11:07 PM
Shandong Bestar Carbon Black Factory, the National Owned Enterprise, produces New Technology Carbon Black. All the exhaust gases generated during the production are exploited to generate thermal power, realized the harmonius unity of economic efficiency and environment protection.
The factory is design 200,000 tons annual capacity, to be covered in three phases. The second phase has been successfully put into production, annual carbon black production capacity has reached 120,000 tons. We mainly produce N210, N220, N234, N326, N330, N375, N539, N550, N660, and other various types of rubber carbon black. With excellent product quality, stable production technology parameters, reasonable prices, our carbon black has won praise from customers home and abroad.
Carbon Black - Grade N220
PropertyASTMMINMAX
Iodine No. mg/gD1510116.0126.0
Oil Absorption, cc/100gD2414108.0120.0
Toluene Discolouration, %D16188.0-
Heat Loss, %D1509-2.0
Tint Strength vs IRB 3#D3265110.0125.0
Ash, %D1506-0.8
325# Sieve Residue,%D1514-0.100
Density, lb/cu ftD151320.024.0
Fines 5 min, %D1508-8.0
300% Modulus, vs IRB6 MpaD412-0.702.55
Carbon Black - Grade N330
PropertyASTMMINMAX
Iodine No. mg/gD151077.088.0
Oil Absorption, cc/100gD241495.0105.0
Toluene Discolouration, %D161880-
Tint Strength vs IRB 3#D326598.0108.0
Ash, %D1506-0.8
Density, lb/cu ftD151321.525.0
Fines 5 min, %D1508-5.0
Fines 20 min, %D1508-8.0
300% Modulus, vs IRB6 MpaD4120.142.90
Carbon Black - Grade N550
PropertyASTMMINMAX
Iodine No. mg/gD151038.048.0
Oil Absorption, cc/100gD2414116.0126.0
Ash, %D1506-0.8
Fines 20 min, %D1508-12.0
300% Modulus, vs IRB6 MpaD4120.303.10
Carbon Black - Grade N660
PropertyASTMMINMAX
Iodine No. mg/gD151031.041.0
Oil Absorption, cc/100gD241485.095.0
Ash, %D1506-0.8
Density, lb/cu ftD151324.028.0
Pellet Crush Strength, avg gD33131050
Pellet Crush Strength, max gD3313-60
300% Modulus, vs IRB6 MpaD412-1.501.30
For More Carbon Blacks Info, Please Contact US Freely.
Rubber reinforcing carbon black factory
Register to Reply 7 comments
agua_doc (1); Anonymous Poster (1); bestar0632 (1); Electroman (1); Ghoti (1); ozzb (1); uweka (1)
