Previous in Forum: Steel Properties   Next in Forum: Ways to Calculate Reynolds Number
Tightening torque for brass bolts
02/09/2008 5:15 AM
Hello everybody,
Questions:
1). What is the maximum tightening torque for brass bolts of M10 size ? I want to
tighten brass bolts on brass earthing bar.
2). What is the property class for brass ?
Could you recommend a comprehensive data sheet/table for this purpose ?
Thanks in advance,
Paata
Re: Tightening torque for brass bolts
02/09/2008 5:29 AM
02/09/2008 11:14 PM
The Bolt is not carrying the Current.
So why not use the highest strength steel (maybe plated) bolt for the current carring members to intimate contact.
Brass serves no purpose.
02/10/2008 9:13 AM
The question is, that equipment has already been commissioned and unfortunately I can not introduce any changes at my discretion. Actually I am going to carry out planned maintenance on equipment and as per job plan I am given tightening torque table in which data for brass to brass is not available. On the basis of available information I can assume, that roughly, torque of 21 - 22 Nm should be OK.
Thanks
02/10/2008 1:11 PM
If you are allowed 21>22N-m, you are fine.
Max. Shear stress at outer skin of 10mm dia will be ~10 N/ sq mm.
Failure of ordinary half-hard 62% Brass will be ~ 200 N/mm sq.
02/10/2008 9:21 PM
Oops ! it should have been 100N/sqmm
(allowed is 200N/sq mm--OK)
You are still OK
02/11/2008 2:17 AM
Thanks for information.
02/11/2008 7:29 AM
Tighen them up until they break, then back them off half a turn.
Register to Reply 7 comments
Anonymous Poster (1); jdretired (1); MUKULMAHANT (3); Paata (2)
You might be interested in: Bolts, Copper, Brass and Bronze Alloys, Anchors
