Previous in Forum: Tightening torque for brass bolts   Next in Forum: Suggest me valve actuation system...
Ways to Calculate Reynolds Number
02/09/2008 5:24 AM
Can you please explain me how to calculate the reynolds number, Discharge Constant and Flow Coefficient of the flow. Let us take an example with th below specifications. Fluid: Nitrogen Gas Pipe Inside Dia: 52mm Pipe Size: 60*4mm (Outer Dia * Wall Thickness) Max. Flow: 3000m3/h Normal Flow: 2000m3/h Min. Flow: 1000m3/h Absolute Pressure: 8 bar Relative Pressure: 7bar Operating Temp: 35Deg C Fluid Density: 1.25kg/m3 (at 0 DegC, 760mm Hg) Installation: Horizontal Material of Orifice: SS Type of Orifice: Ring, D-D/2 tapping, 1/2"NPT connection I alos want to know the difference betwen Ring and other types of orifices.
Blessed is the man who finds Wisdom, the man who gains understanding. Proverbs:3:13
Re: Ways to Calculate Reynolds Number
02/09/2008 11:55 AM
reynolds number=(ρ(density)*v(speed)*d)/μ
ihope to aid you
02/10/2008 3:50 AM
Dear Macsimus,
I noticed that all your threads are related to mechanical engineering, and you are graduated from college in May, 2007 holding a Bachelor Degree in Electronics and Instrumentation Engineering.
So, it will be difficult for you to learn the mechanical engineering from zero through the posts of CR4.
Good Answers: 183
02/10/2008 4:09 AM
To adapt the usual formula for Re which considers a round area the notion of "hydraulic" diameter was introduced
dh= (4*A/P)^0.5
A= area of the considered section in your case it is the ring
P= perimeter of the area in your case the 2 circles limiting the ring
With this relationship you can use the general computation equation as indicated in an other comment.
I p)resume that you are able to do the computations by your self since we are not here to make your work but only to help you come out of troubles.
With respect to the other parameters as cinematic viscosity or dynamic viscosity and specific weight you can help your self in the different manuals of physics
08/24/2023 9:16 AM
In order to <...Calculate Reynolds Number...> one also needs the viscosity of <...Nitrogen...> at <...7 Bar Operating Temp 35Deg C...>.
Register to Reply 4 comments
Abdel Halim Galala (1); nick name (1); noha (1); PWSlack (1)
