Previous in Forum: Super capacitor testing   Next in Forum: Revolution Counter / Tachometer
flow calculation software for orifice plate
02/10/2008 8:16 AM
I am looking for link for flow calculation used to calculate the how much D/P and maximum flow rate for an orifice plate used in pipe line.
many thanks
Re: flow calculation software for orifice plate
02/10/2008 12:48 PM
Did you google your question? I found several...
http://www.pipeflowcalculations.com/orifice/index.htm
Engineering Fields - Piping Design Engineering - New Member Australia - Member - New Member
02/11/2008 3:21 AM
You can do this with flow analysis software. The software we use is Flowmaster v6.5. It will calculate your D/P (which I think might be Pd, Pressure drop). You would need to provide lots more information before an analysis could commence, such as:-
a) Temperature of fluid.
b) Viscosity of fluid.
c) Velocity of fluid.
d) Edge characteristics of orifice.
e) Head pressure of fluid.
f) And on, and on!
You can do rough calculations with a plethora of cheapo' stuff. Just use google!
"A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools!" Douglas Adams 1952-2001. E&OE!
02/11/2008 9:01 AM
efunda.com has an easy to use orifice plate calculator,
02/12/2008 1:13 PM
The equations are quite simple and you don't need special software. Just get the standard desired (ie ISO or API). They spell out all the equations, where to get factors and everything.
My motto is "If you can not do the calculation by hand, never rely on a computer for an answer"
07/15/2008 10:52 AM
You could try the FlowCalc32 orifice plate calculator
AcesFull (1); Anonymous Poster (2); Beej50 (1); Steve S. (1)
