The company I work for is having an issue with the High Voltage burner cable. After time in the oven and if the cable needs to be removed. The cable fails between the core wire and the ring terminal. The outer cover of the coaxial cable is teflon. The end with the ring terminal is in an oven at 190 degrees C.
Below is additional info:
Core wire dia is 0.020 inch
Ring terminal fits a 4-40 inch stud (hole in ring = 0.125 inch)
Ring terminal fits onto coaxial core wire (outer dia of wire end of ring terminal is 0.083 inch after being crimped).
The braided shield wire (ground) not used on ring terminal end, but can not contact ring terminal
After crimping the connection is silver soldered
Teflon heat tube for strain relief fits over wire end of ring terminal and cable
Other end of cable is SMA connector at room temp.
What we need is ideas on how to strenghten the ring terminal to core wire connection? Need to prevent the cable from breaking when removed after being heated in the oven.
Any suggestions or ideas would be great.
Thank You
George
