Previous in Forum: building on beach sand   Next in Forum: StaadPro-Beam (300X750) on Edge of Column (300X1500)
42 comments
Geometry
02/16/2008 4:38 AM
Is it possible to draw a straight line 100mtrs long?
Good Answers: 230
Re: Geometry
02/16/2008 5:08 AM
Hello Guest,
Yes, easy to do in one dimension - a straight wall for instance, and a straight line along it.
A straight line in two dimensions is more difficult, because the curvature of the Earth needs to be allowed for.
But space is curved, so what we perceive as a straight line, may be otherwise.
The other thing to think about, is how much lead is in the pencil, or ink in the pen.
Kind Regards....
Re: Geometry
02/16/2008 5:15 AM
NO, it impossible to draw a straight line.A line as a mere geometric construct...
or
YES, simple, It is done on many sports field.
It depends entirely on your definition of 'staight' and 'line'.
Good Answers: 143
Re: Geometry
02/16/2008 9:19 AM
OMG! It's Bill Clinton doing geometry!
Reply Off Topic (Score 6)
Re: Geometry
02/20/2008 4:40 AM
Thanks. As far as our high school geometry is concerned, drawing a straight line is possible. But as per real geometry drawing of an accurate/ perfect straight line on curved surface of the earth is not possible. Then a long line like 100mtrs will also be not possible. Other points like lead of the pencil and maintaining straightness as far as possible are the practical drawing difficulties. But the fact is that if we keep aside the approximation then drawing a straight is not possible. Similarly the total of all 3 angles of a triangle is not 180 degree on curved surface of the earth. Just think all our calculation of Triconometry goes wrong if we keep aside the approximation. But still we live on approximation and do all calculations, which also becomes practical. But all our practical calculation is not real (if we think in deep and go for finer accuracy). We actually live in approximation, imagination or in illution.
Re: Geometry
02/20/2008 5:39 AM
Moving on to spherical geometry is changing the goal posts somewhat. It's also altered what you mean by 'straight'. Airlines would be in trouble if they couldn't work with spherical geometry. Drawing a 'straight' line on a sphere should be easier since we can rotate the sphere against the pencil.
Re: Geometry
02/16/2008 5:29 AM
This may help with the 'lead in a pencil' trouble. With care, you may be able to manage 550 lines. Occasional sharpening may reduce this figure. Some kind of laser guidance may be needed to ensure 'straightness' of line. A long piece of wallpaper on the side of a skyscraper would be a good stating medium. This would negate curvature of the earth, and also prevent air temperature differentials from skewing the laser guidance system. The pencil should be mounted on a rail and driven by a motor - some clever circuitry could apply the correct drwaing time. For accuracy, effects of wind resistance on the assembly should be taken into account. Slower rates of drawing will give greater accuracy.
Popular Science - Cosmology - New Member United States - Member - New Member
Re: Geometry
02/16/2008 8:25 PM
"The pencil should be mounted on a rail and driven by a motor -"
Of course the rail itself must be straight or....
All worthwhile programmers know that constants always vary.
Good Answers: 247
Re: Geometry
02/17/2008 1:37 AM
Of course, getting the rail straight is easy. Just draw a straight line and set the rail along side, and eye it up. Hammer where necessary.
Re: Geometry
02/17/2008 2:15 AM
I forgot to mention the parachuting monkeys, equipped with atomic clocks and marker pens. Suitable local values of g must be applied, and shaven monkeys will make calculation of air resistance easier. My test pilot, vermin, is depliating as I type.
Good Answers: 50
Re: Geometry
02/17/2008 2:55 AM
The monkeys keep stealing the razors! What's up with that?!
Re: Geometry
02/17/2008 3:00 AM
Nothing wrong with that , it's just unusual. Besides, Occam wants them back.
Good Answers: 143
Re: Geometry
02/16/2008 9:24 AM
If it is possible to draw a straight line of any length, it is possible to draw one 100 m long.
Good Answers: 247
Re: Geometry
02/17/2008 1:41 AM
Any drawn line has three dimensions -- 2 too many for a real, geometric line.
Re: Geometry
02/17/2008 3:04 AM
Yes.
Re: Geometry
02/17/2008 3:11 AM
Use a drawing program with scalability.
Re: Geometry
02/17/2008 3:19 AM
My display is set such that the red box around the question appears to be a very generous 10" x 2". By holding the Ctrl key and using the scroll button, this can be enlarged considerably. Unfortunately my monitor can't cope with 100m, but it's a start.
Re: Geometry
02/17/2008 3:28 AM
How about a Peaucellier-Lipkin linkage ?
Here is more.
Re: Geometry
02/17/2008 3:13 PM
But how do we draw a straight jacket?
Furthermore, how do we draw a Strait George?
Re: Geometry
02/17/2008 6:22 PM
With lots of buckles.
I thought you were talking about Boy George and I was going to tell you your on your own.
Brad
Re: Geometry
02/17/2008 8:18 PM
Boy George ain't got a straight bone in his body.
Let's go back to Kris' pencil on a rail scheme for a moment. Suppose on a windless day we suspend a plumb bob from a 100 M cliff. At the point where it touches the ground, we attach it firmly (the top end is likewise attached firmly). Now, we unroll a sufficiently long roll of toilet tissue beside the plumb line (maybe Scott's 1000 sheets per roll).
With tissue attached top and bottom, we attach Kris' pencil to a trolley which rides freely on the plumb line. Place the pencil tip against the tissue and let go of the trolley. Wallah!! We've drawn a straight line.
Of course we need to select a location where gravitational anomalies are minimal.
-John
Re: Geometry
02/18/2008 1:19 AM
I think we'd need the toilet paper that they used to issue in Schools - the stuff that doubles as tracing paper. The 'quilted' and 'medicated' namby-pamby stuff would disintegrate.
< The jacket strings have to be drawn very tight ! >
Good Answers: 230
Re: Geometry
02/18/2008 7:27 PM
Hello Kris
Whatever you do, don't use this
Kind Regards....
Re: Geometry
02/19/2008 1:18 AM
ROFL ! You have an admirable collection of graphics Sparky. That one possibly even tops the sewing machine, it has so many possible uses.
Good Answers: 230
Re: Geometry
02/19/2008 4:28 AM
Hello Kris
I do try and be helpful to all.
I have nearly 1TB of various Graphics, and adding every day.
When I look for a specific graphic, I generally seem to locate a few more to add to the collection.
Kind Regards....
Re: Geometry
02/19/2008 10:30 AM
Here's my take on it:
Re: Geometry
02/19/2008 12:25 PM
10/10 ! That's a brilliant bit of work JJ. Proceed immediately to the top of the class.
Good Answers: 230
Re: Geometry
02/19/2008 5:48 PM
Hello Johnjohn
Go to the top of the class.
Don't take your books, you'll be back.
Kind Regards....
Re: Geometry
02/17/2008 6:28 AM
Yes, but ... will depend on your cushy hand, the surface and your tolerance concerning roughness.
The sum of intelligence on earth is a constant. And the population grows and grows and .....
Re: Geometry
02/17/2008 1:37 PM
Yes, use a laser and then adjust for the curvature of gravity.
Of course it won't last because the Earth, Moon, Sun, Universe dynamic.
I guess this is dependant on your definition of strait.
Brad
Re: Geometry
02/18/2008 11:18 AM
As far as I remenber (I am a 66 old/young chem eng) Euclides stated that a straight line is an infinite line going through two defined points. The frasing might not be correct but that's the general idea. I think its postulate nr 1 in the 1st book.
Re: Geometry
02/18/2008 12:43 PM
So how do you propose the original poster draw it?
Re: Geometry
02/18/2008 3:39 PM
Since, as previously stated, a straight line (single dimension) is a concept, then conceiving is the only way to "draw" said line. This I was conceiving with great success until Sue with the tight skirt and big ......
Support your local Shriners, they have provided FREE medical assistance for over 800,000 kids so far.
Re: Geometry
02/18/2008 3:48 PM
So now the challenge is to draw a straight line on Sue's body...
Good Answers: 50
Re: Geometry
02/19/2008 1:17 AM
Any straight line that you actually draw, will actually be a very long and skinny rectangle.
Re: Geometry
02/19/2008 5:58 AM
If we put a dot here and a dot there, would not the line exist between automagically, perfectly straight and non-dimensional
Re: Geometry
02/19/2008 7:50 AM
Depends how big the dot is.
Re: Geometry
02/19/2008 6:16 PM
First maybe you can help me with a comment about squirrels. Let me explain. I don't think it matters how big the dot is we are only interested in the line. I proceded to test this in the very large building where I work. It has a very long hall, maybe not 100m but really long. I drew a dot,very small on one end wall then went all the way to the other end and drew a dot on the door, again very small. I then placed myself a ways down the hall began to visualize the connecting line which did seem to be perfectly straight, unwavering, and skinny,skinny. I just about had it all in mind when Sue, who you may remember from post 26 or so came out of her wonderfully smelling office and before I realized it she was watching me as I sighted down my line.
sue: what are you doing?
me: visualizing a line between these two dots.
sue: what dots?
me: One on that wall and one on that door.
(At this point I quit looking down my line and looked at Sue, and I don't know why maybe it was the way I looked,grinned, drooled at her with the tight and...)
Sue: Squirrel (walking -not in a straight line-away shaking her head side to side
Me: Whaa
Do you think I should try to explain it to her later?
Re: Geometry
02/20/2008 2:58 AM
No, no, no,,,,,If she concieved your idea, all will become clear in 9 months. If questioned, I'd just say " Well, I had to draw the line somewhere".
Re: Geometry
02/23/2008 3:20 AM
this invention relates to a practical method of writing long straight lines on long pieces of paper, avoiding influences such as the curvature of the earth etc that may attempt to exert detrimental effects on the straightness of said written line.
take chosen length of paper and wind in a roll onto a damped, dispensing, rigidly held feed roller and feed said paper onto a damped, collecting, rigidly held collector roller, said feed roller and said collector rollers having precise axial parallelity, said collector roller having a powered drive arranged to pull the paper from the feed roller and collect it on the fed roller, much like in the papermaking process which is well known in the art and need not be described any further here.
hold chosen writing instrument in laterally precise, gravitationally vertical contact with the outer diameter of the unrolling coil of paper while allowing / forcing said writing instrument to feed in towards the centre of the unwinding roll as the paper unwinds, while also preventing lateral displacement of said writing instrument and while having means to refill said writing instrument with fresh ink as required, said refilling attachment needing no explanation here since such refilling methods are well known in the art.
turn on said collector roller's drive motor and monitor writing process, refilling said writing instrument with fresh ink, either manually or automatically as required.
aforementioned process can continue as long as operator can find paper rolls long enough to write on, and as long as sufficient ink supplies can be provided to refresh writing instrument with.
of course, the writing process will need to be held in abeyance occasionally to allow for maintenance of previously described rig, such maintennce may entail the replacement of bearings and other wearing parts that are essential to maintain the axial parallelity of said rollers and the precise and good working order of other essential parts, such as the writing instrument etc.
Good Answers: 50
Re: Geometry
02/23/2008 3:36 AM
By any chance are you a lawyer for said Geometry?
Re: Geometry
02/24/2008 7:21 AM
just practicing my patent writing.
Re: Geometry
02/23/2008 5:06 AM
s it is possible to draw a 100m striaght line . u can have a trace while traveling and u can take example as train track 100m is not at all a problem
ragavan
Reply to Forum Thread 42 comments
Abdel Halim Galala (1); Anonymous Poster (5); Blink (2); JasBond (2); Johnjohn (6); Kris (11); Mercor (1); ragavan (1); Sparkstation (4); TVP45 (2); U V (2); user-deleted-1105 (1); uweka (1); vermin (3)
You might be interested in: Line-shaft Spools, Power Line Network Components
