what is the De rating factor for power cable is running in tunnel
In one of my project, i calculated cable size between 33kV switchgear and PDT transformer in normal over head cable routing.distance between 33kV switch gear and PDT transformer is around 900 meters.
The problem is we have to cross the main road approx 25 meters ,so we have to run thru the tunnel of size 25 Meter (L) X 2250mm (H) X 1400mm(W).(both side closed with vent pipe for air circulation)
if i take the de rating for the tunnel ,then i have to go for 2R X 1C x 630sq mm.that means it will double my total length approx 14000 Meters instead of 7000 meters
Can we ignore the 25 meters Tunnel length
i checked up the STD (IEEE ,IEC ,IS etc) also.
