Previous in Forum: Gears   Next in Forum: Centrifugal Pump Breakdown
Maintenance Engineer
02/19/2008 4:33 AM
  • Where can a centrigugal pumps be used.
  • what kind of fliud passes via it.
Re: Maintenance Engineer
02/20/2008 1:07 AM
The centrifugal pumps can be used in so many places e.g. water supply, coolant,.....
And any fluid can pass it.
Nature is unlimited, human's knowledge is limited
02/20/2008 3:18 AM
SO MANY PLACES??? WHAT DO YOU MEAN??? I think Centrifugal pumps are commonly used to move liquids through a piping system. Not any fluid can pass it, water and oil are more popular.
Engineering Fields - Mechanical Engineering - By Degree Engineering Fields - Manufacturing Engineering - By Profession Popular Science - Weaponology - By Interest United States - Member - Member Since My Inception
02/20/2008 1:02 PM
Just because water and oil may seem more popular, does not mean that's all that will go through it. Look into the links my post above. Centrifugal Pumps have been around for quite some time and are used to move ALL types of fluids, along with some solids.
Light travels faster than sound. That's why some people appear bright until you hear them speak.
02/20/2008 12:59 PM
Centrifugal Pumps are the most common and well-established pumps on the market. They come in many different models and can transfer fluids with high efficiency over a wide range of flows and pressures.
Basic centrifugal Pump Info
Global Spec's "About Centrifugal Pumps
Some Applications
02/20/2008 1:53 PM
I'll really confuse you all. I install a Bingham split case pump to pump ethylene gas from 850 psi 80F to 1650 psi. so I guess any fluid.
02/27/2008 6:43 AM
Stay with low-viscosity fluids. Anything like Lyle's Golden Syrup or strawberry jam needs a different style of pump; lobe pumps are good for these fluids.
Blood is pumped better with a peristaltic pump fitted with sanitary tubing.
All About M.E. (2); Anonymous Poster (2); nam70 (1); PWSlack (1)
