We have been experiencing frenquent breakdown due to vibration in our centrifugal pumps. we have done all we could to stop the vibration. All efforts doesn't seem to work what shall i do in this regard?
Kindly detailed the frequent breakdown of the pump? What is the symptoms of pump failure?
If you are not familiar with the symptoms of pump failure, then it will be very difficult for you to root-cause the problems. To start with, better to take some photos and share it to the forum in order to verify visually and perhaps somebody can evaluate the symptoms that leads you to the cause of failure.
How did you know that vibration is the cause of failure? Please support your findings!
If the pumps sound like there are marbles in them then they are cavitating.
Large pits in the impellers or bodys are also a sure sign of cavitation.
Tip: if the impellers are open faced, set the clearance from the back. If they are closed face, set the clearance from the front. I dunno why but it works.
If the centrifugal pump is being used on either condensate recovery from a steam system, or steam boiler feed water applications, then the problem is cavitation.
How do you fix cavitation with hot water/condensate as the source? You can't - it is an inevitability of electric pumps that see water temperatures in excess of 200 deg F.
If the problem persists, then you may want to consider an alternative method of returning condensate: non-electric Pressure Powered Pump.
A non-electric Pressure Powered Pump can be operated using either high pressure steam or gas (such as air).
