Previous in Forum: HuckLoc Rivets   Next in Forum: Harness diameter calculation
28 comments
Triggering Traffic Light Detectors
02/22/2008 8:41 AM
Hi, I've spent too much time sitting at traffic lights on my motorcycle hoping that a car would come and trigger the light because I'm not being detected. I understand that if I carried a big enough slug of metal, I would be detected, etc... and if I went to an intersection that used optical detection, I would be seen. But I want to do this differently.
I want to design a box that will tell the vehicle loop detectors that I'm there.
As far as I can tell, they operate at 20 - 120 KHz, but what is it that says "There's a vehicle here!"? Is the loop excited and the resonant frequency measured.. and if it changes, there's a vehicle there? Is the loop used in a pulse-listen technique, a la anti-theft systems?
Thanks for any direction you can point me, any sites that would be helpful, or any information you can provide...
Thanks
Rachel
Norristown, PA
Good Answers: 266
Re: Triggering Traffic Light Detectors
02/22/2008 9:29 AM
Disruptions in the magnetic flux by the metals in the vehicle.
Don't know where you are that you are having a problem but the one on our plants automatic gate picks up motorcycles just fine.
02/22/2008 11:44 AM
I'm right with you on the frustration factor. Fortunately it rarely happens on my normal work commute or on my usual fun routes, but I have had it happen at other times. And I've heard many, many others complain about it.
I assume you've heard of putting some neodymium magnets under your motorcycle, yes? Supposedly this gives you enough extra magnetic "oomph" that you'll trigger the light. You can find them for sale in biker catalogs or order them through a variety of other sources. I don't know if it works - none of my riding pals have ever tried them either - but it seems worth a shot. Here's a like to a video that seems cheerfully optimistic:
http://www.metacafe.com/watch/828731/trigger_green_traffic_lights/
02/25/2008 12:33 PM
I have had this problem in the past. I now have a strong magnet at the bottom rear of my front fender. I stop the bike so that the rear of the fender is over the road sensor. No more problems. Most bike shops in my area sell these magnets. Just get one and put it on the lowest part of your bike. Then stop your bike with the magnet as close to the road sensor as possible.
Good Answers: 918
02/22/2008 12:10 PM
I don't think you can legally do that. I would start by complaining to PENDOT and see if you can scout out other motorcycle clubs that have members that have that problem.
It may be that you are finding a number of lights that do not have the correct vehicle sensitivity and they should be fixed if they don't meet spec.
I think the problem is PENDOT's (or the local community that owns them) and you shouldn't have to spend a dime to have the problem fixed (you already paid the taxes).
By the way, I used to live just down the road from you in Spring City, PA.
02/22/2008 3:01 PM
Then why is 'frequency' an important parameter? It does allow adjacent system not to cross-trigger, but if you're just looking for a change in I or V because the inductance changes in the presence of the earth's magnetic field when the vehicle comes by, I wouldn't think this would be an issue. Hmmmmm, maybe it's the change in V or I as the loop is being driven and the car comes by...
Out on the roads, often for left turns or from smaller roads onto more travelled roads... it is especially frustrating when sitting in a left turn lane through 3 - 5 cycles of the light... until a car comes up and I move up so the car can trigger the loop sensor...
I have heard of this, but I've also heard more people say they didn't work than thos that thought they did... I also have heard that Virginia tells you to move around in the loop. And, if that fails, turn off your engine and start it up - running the starter is supposed to produce enough noise that it should trigger the sensor.
RE: legality - I'm not looking to use the system that emergency vehicles use, I'm only looking to trigger the sensor that should already be triggering if it were adjusted properly. Yes, local athorities should take care of it, but that doesn't mean much when you're out for a ride, sitting at a light, and wondering how long you should wait before just going on through...
yeah, that's my suspicion.
Well there's what I should have to spend and what I will spend to avoid problems... I question the magnets' effectiveness, and I would spend more for an electronic box if it would really do the job - and I am even more interested in developing such a box and selling it to my fellow motorcyclists if I can really believe that it would do the job.
Hey! A local! I go past there when I'm out for weekend rides... (no, I don't think any of the lights that I'm having problems with are in that town ;-)
Thanks for the inputs!
Rachel
Norristown, PA
02/23/2008 12:16 AM
Hello Rachel
Ozzb: said Don't know where you are that you are having a problem but the one on our plants automatic gate picks up motorcycles just fine
I figure on killing two birds with one stone here. A more pertinent question is where Ozzb is located, nobody in California knows how to install the road sensors, possibly a look at a working example would help them.
I've been riding motorcycles for over 30 years now, and the odds haven't changed much, a little better than even money that a motorcycle will trip the sensor.
Caltrans engineers are diabolical . Some left turn lanes feature multiple sensors, and will apparently skip a cycle if there's only one vehicle in the lane. So you never know whether the light is malfunctioning or not.
Besides running the light, a technique that sometimes works is to approach the sensor as diagonally as possible. This puts a little more metal over the sensor, the best I can say is sometimes the magic works, sometimes it doesn't.
A caveat to that is this maneuver leaves you in a bad position for rapid acceleration through the intersection. Repeating a phrase that has already been used. I don't know where you're at, around here as soon as you move the motorcycle to a diagonal position , this guy called Murphy usually appears from nowhere, slides up behind you, trips the sensor, and lays on the horn.
PS. Let me know if you come up with something, I may be your first customer.
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore all progress depends on the unreasonable man" George Shaw
Good Answers: 39
02/23/2008 12:55 AM
Road runner gave part of the answer. Some traffic controllers are set to not trigger on one vehicle. It has to count TWO vehicles.
Solution; back up behind the sensor coil and then drive through again. Now light triggers.
Back when I was young and foolish; a favourite trick to shake a tailer was to cut the corner and drive up the wrong lane thus triggering the coil and giving your tail a red light to run. If they didn't have balls they stopped. <grin> and lost! Then the cops got smart and had the controller's counter reset to need two counts (vehicles) to trigger the light. Grrr!
Try it.!
Elnav
02/23/2008 3:14 AM
Hello elnav
I'm glad to know I'm not crazy. I thought those left-hand turn lanes were requiring two vehicles to trip.
Approaching the sensor diagonally works on the gate at my friend's condo.
I have seen some sensors that seem to be laid in a circular pattern (I told you Caltrans was diabolical) which makes the diagonal approach difficult to say the least!
I Google traffic loops sensors. Supposedly improvements are coming, a change in technology to say infrared. It also appears that big brother is going to be doing a little more watching.
  • "Certain new detectors output vehicle inductive signature through a serial port on the detector card. These vehicle inductance patterns can be used to identify vehicles, measure travel times, classify vehicles and determine vehicle origins and destinations."
  • I have thought about setting up a coil and a capacitor (like a polarized magnetic charger) and seeing how that affects the loops. My luck that EMP would fry the sensor and the ignition on the motorcycle, and I be stuck there all day. The tried and true method of waiting one cycle then running the light seems to be the best low-tech solution, and a good excuse for running red lights.
  • PS. What are you doing on this thread? It's too blasted cold to be riding motorcycles in Canada this time of year. Stay warm Y. W.
Good Answers: 266
02/23/2008 1:12 PM
Well then you need to get together as a group in your areas and have the issue looked in to. There are sensitivity adjustments on the controls. At one time there were some complaints about that around here. Most have been taken care of. Harley Davidson of Baltimore and the clubs take great effort to sponsor charitable events. I guess this has its benefits.
United States - Member - New Member Popular Science - Weaponology - New Member
02/23/2008 12:59 AM
This may not be of much help in Pa but in California if the detector fails to respond to your vehicle after a couple of cycles you may proceed when it is safe to do so. Check out Pa law, it may be the same. Of course it is still annoying no matter how you look at it.
Men are like steel, if they lose their temper they are worthless.
02/23/2008 2:57 AM
I try to slow way down before reaching the coil, then approach near one side, so more of my bike is close to the sensor.
Another old trick is to lower your sidestand over coil.
02/23/2008 8:16 AM
I also live in cali and both of the above mentioned posts are correct. What works for me is if I pull up to the sensors completely to one side, having the whole bike along one side of the sensor. You can see where they installed them and easily do this.
02/23/2008 10:54 AM
Hello AcesFull:
Thought I say hi from Cypress. The one thing we have going for us here in Southern California is there's usually a car around a trip to the censor, minus late evenings or early morning rides.
Now that this thread has got me ticked off Again about getting stuck at traffic lights,I'm going to try yours as well some of the other techniques mentioned, I may even build my flux capacitor (seems like a good name considering the way the detectors work), you never know might lead to a marketable product.
PS. If you see a candy green ZRX1200 making about twice the speed limit say hi, it's probably me
02/23/2008 12:50 PM
What's up Runner? If you see a K7 gixxer 600 going half the speed limit on the 91 freeway, say hi, it's probably me. I just paid a $700 ticket and learned how slow these bikes can actually go. As far as traffic lights go though, the approach I mentioned has worked for every light I had trouble with other than the exit from the 91W turning left onto Imperial Hwy. I arrive at it at about 4:15am everyday and usually give it 2 or 3 missed cycles, wait for a clearing and go through the red.
Good Answers: 97
02/23/2008 2:13 PM
I thought that was a stop then go light...DUH! (:
02/23/2008 8:49 AM
I am no expert on these issues. However, if the problem is to increase the magnetic permeability of the bike to the point where it exceeds a threshold, the permanent magnet technique would not work.
That same problem exists in small AM radios. The solution there is a small "flux sucker", a piece of ferrite. Ferrite is not expensive, is lighter than carrying around a VW engine block, and may help get you over the threshold of magnetic permeability.
Good Luck
Hobbies - CNC - New Member United States - Member - New Member
02/23/2008 8:56 AM
I never heard of using magnets before this. In Indiana and Kentucky I have found it best to approach a left turn lane sensor on the extreme right side of the box. I have encountered this problem on with my Electraglide Classic. Not a small bike by comparison. I still have problems tripping sensors once and a while. I typically find myself avoiding traffic lights by taking alternate routes out of habit. That started back in the seventies when pressure plates were still being used.
Good Answers: 42
02/23/2008 11:30 AM
When I was in university the gate and a traffic light to let out vehicles was also the one for bicycles. The bicycle never tripped the gate and light. Solution was to use a heavy chain for your bike lockup, then momentarily drag it across the sensor as you approached. It took a little practice but worked.
02/23/2008 11:34 AM
I just found this link. I don't know if the device works, I'm going to do a little more research.
For $24.95, I may try one, if it doesn't work, I can always sick the credit card company on them.
http://www.greenlightstuff.com/
02/23/2008 12:24 PM
Yeah, that looks like what I was planning on developing... just could never get enough information about how those things really worked...
sigh
thanks!
Rachel
Norristown, PA
Good Answers: 97
02/23/2008 12:38 PM
Some kids on my route think it's fun to make vehicles stop
02/23/2008 6:20 PM
My son uses a little magnetic device that he bought online to trip the light sensor. It attaches to the underside of the bike frame. He says it almost always works!
Remembrance is the golden chain that binds our hearts together.
02/23/2008 9:46 PM
Here is something that may help:
http://www.humantransport.org/bicycledriving/library/signals/detection.htm
Detection of Bicycles by Quadrupole Loops
at Demand-Actuated Traffic Signals
Steven G. Goodridge, Ph.D.
Member, IEEE
Location: Earth. England/America -the birthplace of the C. S. A. - anywhere I imagine -home.
02/24/2008 1:27 AM
We can run a Rover on Mars by remote control, see golf balls from orbit and detect all kinds of objects electronically, but we can't do something as simple as control traffic lights. I don't think they want to because it would reduce revenues from traffic tickets and it would cost a bit to do it right.
No technology is so obsolete that it won't work. A stone knife still can kill you as dead as a laser.
02/24/2008 7:09 PM
drive in the middle of the lane it will work better for smaller vehicles
02/25/2008 5:19 AM
try to look for it in youtube, i saw it there
02/25/2008 9:06 AM
On the back of one of my MC club newsletters they had a product to remedy that problem. It was a heavy magnet that mounted below chassis and was supposed to trigger the embedded switches in the road. I have this problem crossing a highway leaving my home. Unless there is a car behind me i have to run a red light to cross it or ill sit there forever.
I have yet to test this product,but i have heard from a few people that it works.
02/26/2008 7:53 AM
One solution is to adopt the technique that the experienced push-cycle user adopts for safety: on approaching a set of lights and assuming one is not turning (UK & Eire) left and that it is safe to do so (a quick glance over the right shoulder will do...), track across into the centre of the lane and force a queue to develop behind. The cycle passes over the detection loop and, if it doesn't trigger the detector itself, a following road motor will do so instead.
Upon the lights clearing to green and it being safe to proceed, track back to the (UK & Eire) left side of the road upon clearing the junction to give faster traffic the opportunity to pass safely.
Register to Reply 28 comments
AcesFull (2); Anonymous Hero (1); Anonymous Poster (5); bwire (2); elnav (1); garyceng (1); GW (1); jcrock (1); ozzb (2); pantaz (1); PWSlack (1); RAdamec (2); rockshop (1); silvCrow (1); Taganan (1); The Mechanic (1); YWROADRUNNER (4)
