Previous in Forum: Electrons   Next in Forum: Transmitting Brain Waves to the Internet?
RS485 communication Noise
02/22/2008 9:08 AM
hi to everyone here!
I have query about some noise cancellation technique.
I have ARM kit which is configured to have RS485 communication with an AC drive.
The GND wire between drive and ARM kit is only one, along with 485 cable(approx. long of 1 feet) .
Now when ARM starts communication with DRIVE via 485 , the o/p leds connected to othe port pins get signalled randomly.
This happens sometime and does not sometime.(i.e. randomly.)
How can be tackled with this situation?
Any suggestion will be heartly appriciated!
Thanks & Best regards!
Engineering Fields - Instrumentation Engineering - New Member Hobbies - Fishing - New Member
Re: RS485 communication Noise
02/22/2008 10:32 AM
1. Try to reduce connection speed. For instance if you have 57600 change it to 19200 or even 9600.
2. Make measurment of RS485 with scope for applying terminating resistors.
3. Employ RS485 repeater with optic isolation.
4. Use check sum data transmitting technique.
5. Use majoritary data sending technique.
6. Use twisted pair wire.
There are common recommendations for power supply filtering, shielding and etc. which you can google independently.
Good luck.
Good Answers: 97
02/23/2008 12:45 PM
Good Answers: 97
02/23/2008 2:43 PM
First define noise, what type do you mean? Corrupted electrical? Audio?
Ground wire- you can sometimes eliminate some noise by adding a separate wire wound around the other not in the usual twisted pair sort but looped, if a 1' ground then wind every 2" and connect to ground lug at each end.
Good Answers: 80
02/23/2008 11:18 PM
Make sure that the drive and the motors are grounded properly. Do not ground the shield of the communication cable at both ends, it would allow noise to flow through it. The drive control and the receivers must be at similar ground levels if a communication link isolator is not used.
Good Answers: 97
02/24/2008 12:49 AM
Try googling "RS485 cheat sheet" for answers
02/25/2008 5:15 AM
Noise in 485 comms. is invariably during the tri-state period not the active period. Try biasing the termination.
Register to Reply 6 comments
bwire (3); caramba (1); marcot (1); Randall (1)
