Previous in Forum: Flash Actionscript   Next in Forum: CD Drive Mystery Operation
CAM software needed
02/24/2008 12:32 PM
Hi guys,
Does anybody know an appropriate CAM software which converts SolidWorks file into G-Code for plasma machine cutting?
I work with SolidWorks but I need to do dwg filles for the plasma cutting machine. It's kind of wasting time.
Good Answers: 97
Re: CAM software needed
02/24/2008 1:31 PM
Have a look at MasterCam.
02/28/2008 2:13 PM
Cam Express by Siemens will do the job and more. It will read your Solid Works files saved as ParaSolid, STEP 203/214, IGES, or DXP/DWG.
03/06/2008 4:58 AM
So, you mean I will have my part file saved as Parasolid and through NX Express Cam I can have it cut on my plasma cutting machine?
I will explain what we do now so it gets certainly clear. I design my object like a steel bus bar which is 100x50x5, then I save the 3D part file as a Drawing in SolidWorks (Scale 1:1), then I save that Drawing file as Dwg file for AutoCAD and then draw the paths in AutoCAD, in other words the edges along the sheet metal that I need to be cut.Then I save that file as .txt and go through G-processor on the plasma cutting machine's PC.
Long long way to get a simple part cut.
Register to Reply 3 comments
Anonymous Poster (1); bizzybone (1); Hendrik (1)
