Previous in Forum: How to Select the Size of HT Cable   Next in Forum: Ammeter Used for Measuring One-Phase Current
17 comments
Fault Level of Sub Station in India
02/26/2008 6:15 AM
Are there any standard guidelines for Fault Level for different voltage size sub stations in India. i.e Fault level for 33KV, 66KV , 132KV, 220 KV etc. If yes please send me the information or from where it can be gathered.
Re: Fault level of sub station in India
02/26/2008 7:03 AM
350 MVA for 33kv
650 MVA for 66 kV
and so on. Refer CBIP publication 256/145 etc. or Technical Report No. 9
BNDas
02/26/2008 11:03 PM
Can u please tell me from where i can get this publication or can u send me the data if u have
02/26/2008 11:15 PM
Here is the better figures obtained from CBIP.
415V 50KA
3.3kV 40KA
6.6kV 500 MVA
11kV 750 MVA
33kV 1500 MVA
66kV 2500 MVA
132kV 5000 MVA
220kV 10,000 MVA
Figures given in previous comment shall be replaced by the above.
BNDas
02/26/2008 11:27 PM
according to me the fault level depends on the No. of generating station, transmmition line. so, how can we decided from transformer ratting ?
02/26/2008 11:30 PM
You know transformer limits fault current also?
BNDas
02/26/2008 11:44 PM
i have no more idea.but i know only that we can find transformer current limit by its rating(KVA) and its voltage level.please reply me.
02/26/2008 11:54 PM
Impedance restricts the fault current.
BNDas
02/28/2008 2:33 AM
please give me idea about fault level calculation.
07/22/2016 1:31 AM
According to this figure at 132 kV fault current comes out to be 21.86 kA, but in realilty there are switchgears of rating more than this value! How come? Pl clarify
09/14/2017 1:28 AM
Thank you very much @biswansth.das
The data is very informative.
Could you please provide me with that single sheet of paper from the publication.
I would be highly obliged if you could help me in this regard.
Re: Fault Level of Sub Station in India
02/28/2008 12:31 AM
Normally fault level depens on the client requirment. A 33 kV System can be designed for 31.5 kA , a 132 kV System is designed for 40 kA with highest fault current for the transformer is considered.
220 kV GIS systems are designed with a fault current of 50 kA.
The other important aspect is the time in secs for the fault current. Again 40 kA for 1 sec is designed for Transformer used in the 132 kV System. 50 kA for 1 se for 220 kV System and 31,5 kA for 3 secs are designed.
As I empahsised it depend upon theclient requirement and the important equiment like Transformers are designed for highest levwel of fault current.
A 400 kV System is also designed for 40 kA for 1 sec.
This is based on the practical application being implemented in at the projects.
Regards,
N.Suresh
02/28/2008 12:41 AM
I am having a transformer of 2500KVA with impedence 6.75%, I want to take independent feeder from electricity supply co.'s sub station (66KV). the line voltage will be 11kv, I just wanted to know the fault level of 66KV sub-station(If any standard guidelines in Haryana or India), so that i can select the VCB and HT cable size
02/29/2008 8:19 AM
Dear friend,
The CBIP norms are considered for any design basis in India. For 11 kV feeder fault level must be equal or less than your transformer SC fault current level.
Regards,
N.Suresh
04/17/2008 6:10 PM
A possible guide to maximum 11kV Fault level is that if the 2.5MVA transformer is assumed to be on infinite 66kV bus bars, then the maximum fault level at the substation 11kV bus will be 2.5MVA divided by %Z.
THerefore the maximum fault level at 11kV will be 2.5 divided by 0,0675 (pu) = 37.037MVA. Corresponding to 1.94kA.
juke
07/14/2008 2:34 AM
The Fault lvel in india is considered as 350 MVA.
02/28/2008 12:42 AM
No, it always not as per client's requirement. The type test for the particular fault should be done from recognised laboratory. Standard fault level switchgear is available in market, you have to design your system as per the availability. Anything special will cost money and time, thereby delaying the project.
BNDas
01/30/2018 1:02 AM
Dear sir ,
In India all state electricity board Fault Level of Sub Station i want know please help me where can i get from standard data.
reagrds
swamy
Register to Reply 17 comments
achawla77 (2); Anonymous Poster (3); biswanath.das (5); dharmendra_prp (3); kamaljeet.s.saluja (1); Rumaan (1); shivamurthyswamy (1); vyral2311 (1)
