Previous in Forum: How to Control Process Heating of Diamond Cutting Through Laser?   Next in Forum: Would a thin-film distributed Bragg reflector be a one-way mirror?
11 comments
Flashpoint of Hydraulic oil
02/26/2008 10:56 PM
I am a elevator inspector from Canada and have a question about when will hydraulic oil become flamable. I have heard many theories and of hydraulic elevator machine rooms exploding but does the oil not have to be heated and atomized before it becomes flamable.
Your friendly neighbourhood elevator inspector
Pathfinder Tags: hydraulic oil
Re: Flashpoint of Hydraulic oil
02/27/2008 3:54 AM
What does the supplier's Material Safety Data Sheet say?
02/03/2011 11:44 AM
int mind blowing anware....
nilesh from MRPL, INDIN.
Good Answers: 183
02/27/2008 5:41 PM
It can become flamable if the vapor temperature is high enough. The atomization has as effect only a drastic increase of the contact surface between oil and air. But only if the temperature is high enough it will burn. It is necessary to start the chemical reaction and this can be done only if athreshold is reached.
Good Answers: 266
02/27/2008 6:59 PM
The oil is being heated the effects of being pressurized by the pump. Hydraulic oil can get very hot as its worked. The size of the tank is usually determine by this heat build up. A larger tank has more surface area to dissipate the heat and more oil will hold more heat. If the fluid level drops then there is less surface of the tank to dissipate the heat an less oil to hold it. I have seen where hydraulic oil has gotten so hot that it melted the plastic that the sump filter had been made of. At this temperature you would have flammable gases being expelled from the tank breather as the fluid level changes. In a enclosed environment they could build up enough to be ignited by the spark at the contacts of a motor starter. Even with out the excessive heat a small rupture in a line could spray oil in fine enough particles to cause the same out come.
Hydraulic oil is aways flammable just a takes a little more to get it going. Its in this heated and atomized state that it become explosive.
02/27/2008 8:04 PM
Thanks alot for this information it is very helpful.
Good Answers: 183
02/28/2008 4:27 AM
In your explanation there is an error you let yourself be guided by what happens in a compressor where effectively the air is heated by compression. The heat source in hydraulic systems is the pressure drop in restrictions. This the reason systems with a motor directly connected to the pump will have less heat problems. All leaks are as well sources of heat. What you said with respect to the low level in tanks is correct and usually there is a level control which warns if for any reason the level is too low.
In systems where control leads to high losses (servo valves for instance) it is recommended to have the benefit of a controlled cooling with help of a heat exchanger oil-water or oil-air.
Re: Flash point of Hydraulic oil
02/28/2008 7:07 AM
FLASH point and FIRE point.
Both are part of the lubricant or hydraulic oil product's specifications, and are given by the manufacturer's tech sheet.
  1. FLASH POINT: is the lowest temperature to which a lubricant must be heated in order to vaporize. At this temperature and with the addition of air it will ignite but will not sustain fire.
  2. FIRE POINT: Is the lowest temperature in which the lubricant will vaporize, and with the addition of air will ignite and will sustain fire.
The difference between the two points, is usually 8-10%. A way to determine the quality of the lubricant, is to heat it up to the flash point. If it ignites below it's specified flash point, it means that this is either a low quality oil or lubricant, or it has passed it's useful life. Another good reason to thoroughly bleed all hydraulic systems, and if open to the atmosphere, make sure these temperatures are not reached.
Hope it helps.
Wangito.
Never trade luck for skill.
02/28/2008 8:33 AM
The flash point of the fluid we use (and many others) is 227 Deg C (440 deg F) depending on the grade, yours may be different. My memory Que is the title of the Fahrenheit 451, By Ray Bradbury. The flash point for paper.
The test we use is the open cup method. That is: the sample is heated in an open cup in the presence of a hot wire or flame. When it reaches the flash point it goes poof, or something like that.
Hope it helps.
02/28/2008 10:09 AM
There are 3 widely recognized test methods for measuring the lowest temperature at which a liquid will emit enough vapors for ignition to start.
The first is Tag Closed Cup, which is used for light solvents (Stoddard Solvent,kerosene, paint thinners). A water bath is used to heat the sample which is in a closed cup. Periodically a port in the top is opened and a standard flame introduced to the vapor space. Obviously the test is limited to materials with a flash point somewhat less than the boiling point of water.
The second, Pensky-Martin Closed Cup , is normally used simulate storage tanks and closed or poorly ventilated reservoirs of materials like jet fuel,diesel fuel, light lube oils, hydraulic oils. The sample flash point could be anywhere from ambient to 400F or even higher. In this method, the sample is agitated while the cup containing the sample is heated at a specified rate, a port in cover is periodically opened and a standard ignition source placed in the opening for a second to see if the vapors ignite.
A third test method is Cleveland Open Cup, which is typically used for heavier materials like lube oils, heavy fuel oil, asphalts and similar materials with flash points over 300F. The sample cup is open topped, not agitated, and heated at a specified rate, and a standard flame is swept across the top of the cup at specified temperature increments to determine when the sample 'flashes.'
Still another test , the Cleveland Open Cup Fire test, continues the heating until the sample sustains a flame.
There is another very important characteristic of petroleum products (auto-ignition temperature or AIT) that is seldom tested directly because the Pensky-Martin test method results, if used correctly, provide a good reference temperature for safe operation in most applications. However it is not the end all answer.
The U.S. Navy conducted an extensive series of auto-ignition tests in the 1940's, and that work is the definitive standard for AIT. The publication was rescued from obscurity in the early 1980's when a massive hydro-processing refinery complex was being designed for Chevron in Richmond California. I was the rescuer. The Navy researchers discovered the AIT of petroleum products was NOT strongly related to the 'flash point' or 'fire point temperature, but the length of the carbon chains in the molecules. A 4 carbon chain has the lowest AIT. The sample is dripped onto a hot plate, the temperature if which is raised between trials. When the dripped sample spontaneously ignites, the hot plate temperature is taken as the lowest temperature which will cause auto-ignition -the AIT.
If a 'synthetic' or hydrocracked (highly paraffinic) hydraulic oil drips or sprays on metal surfaces at a temperature above 200F, it is very likely to auto-ignite. Naphthenic oils, which are used in very low temperature applications (cold climates,etc.) have much higher auto-ignition temperatures. Properly formulated naphthenic hydraulic oils are inherently safer than paraffinic ones, but are more likely to cause varnish and gum if not properly inhibited against 'oxidation'.
In summary, the circulating reservoir temperature is very important to oil life and safe operation, as are the fulid retention (no leak) integrity and insulation of hot surfaces than may get oil drips. Reservoirs and equipment rooms MUST be well ventilated and or purged to prevent the accumulation of explosive or combustible vapors. Inert gas blanketing of reservoirs is often used in industrial applications, but presents asphixiation dangers in closed or poorly ventilated rooms.
Keith E Bowers, PMP
02/28/2008 4:37 PM
Thanks very much I could not have asked for a better answer. All of the machine rooms for hydraulic elevators are supposed to be ventilated. When I do inspections on new equipment I find alot of Mechanical Engineers and Architects miss this requirement and sometimes it can cost alot of money to fix.Thanks again
04/04/2008 4:19 PM
The flash point is where the fluid vapor or il is at a combustable level should an ignition source be present. The fire point is the temperature at which the fluid will self ignite.
First of all you should never be runnning a hydraulic system over 155 deg for industrial applications and 180 deg F for mobil application...which is well below the flash point of any oil. If your operating temperatures are above this you have a poorly designed system or there are components that are not properly adjusted...such as relief valves, reducing valves, flow controls, etc. The pump compensator could be set lower than the relief valve, which would create a big heat source.
If you still have problems with high oil temperatures, you should consider a larger air to oil cooler. Even if it doesn't have a fan, simply adding a source for heat dissipation will help reduce heat and the heat loss can be easily calculated.
Register to Reply 11 comments
Anonymous Poster (2); Keith E Bowers (1); nick name (2); ozzb (1); Paddler (1); PWSlack (1); Travis (2); wangito (1)
