Previous in Forum: TMR VS QMR   Next in Forum: FF PLC
Air Flow Sensor
02/27/2008 1:55 AM
Hi there
We are looking for an air flow sensor. It needs to measure air flow at up to 200 liters per minute at about 3bar of pressure. The output should be 4-20mA and it can either be hose mounted or some screw thread of about half and inch.
Alfred Khumbulele Njeza
Production Manager
Stone Three Signal Processing(PTY) ltd
email: alfred@stonethree.com
web: www.stonethree.com
Re: Air Flow Sensor
02/28/2008 5:15 AM
How about a variable area flowmeter with an attached transmitter?
http://www.mess-regeltechnik.at/platon/main.htm#VAMPIRE (usual discalimer).
Re: Air Flow Sensor
02/28/2008 11:07 AM
There are many different types of flowmeter that would do the job as you have described it.... But there are further specifications that are needed to narrow down the search first...
Such as accuracy required?
The flow range or 'turn down' - is it only 200 l/min or 20 to 200 l/min?
How is it to be mounted, what supplies are available etc... environmental conditions and so on...
John.
