Previous in Forum: combustion   Next in Forum: Automatic Guage Control / MOOG 79 Servo-Valves
23 comments
Popular Science - Weaponology - New Member Canada - Member -
Location: In the sticks of the Central Kootenays, BC, Canada
Questions on threading of reinforcing bar
02/27/2008 11:49 AM
Hi! I'm helping a friend with a manufacturing problem. He has to put 24" of 1" NC left hand thread on many thousands of pieces of 1" rebar. It is for some kind of rock bolt in the mining industry.
He is using a lathe for the rotary drive and using a floating die head with four individual thread cutters--a "Rigid" brand die head that most all of us have seen in machine shops and maintenance shops all over the world. It makes a thread, but the quality could be better.
Here's where we need help:
1. The die head does not seem to run down the center of the rebar. Since the rebar is not fully 1" in diameter in places, the threads don't go to full depth. The best we can hope to do is cut the same depth all the way around the bar. But this doesn't always happen. It seems like the die head occasionally tracks off to one side, even though it is floating.
2. What kind of cutting tools would make the best cut in this kind of material? Its not very good stuff, being made from compressed Toyotas and the like, and has lots of hard spots. There is lots of tearing of the thread. Is this an application where carbide or titanium nitride coating will help? Or are we just as well off with flooding with heavy thread cutting oil? (I don't think thread rolling is in the cards for this job--it is just a one-off and the volume, even though it is large, is probably not enough to justify the cost of the appropriate machine.)
3. What is the best way to do quality control on the threads? By this, I mean that we should be able to ensure that a nut will hand thread onto the completed thread without binding. But actually hand threading a sample onto every finished rod would be very time consuming and costly. A thread mike is good for a very short section of thread. We have 24" of thread on every piece. Is there a better way?
Thanks,
Jon.
Re: Questions on threading of reinforcing bar
02/27/2008 12:09 PM
As you said, rebar material is pretty low quality, and rather inconsistent in alloy. I don't believe you will ever get very good results with thread cutting.
Are you machining the bar to "major diameter" before threading? I would do that, then run the thread die -- without removing the bar from the lathe between operations.
Also, get in touch with the thread die manufacturer for recommendations on feed/speed and lube
02/27/2008 12:43 PM
Rebar was never meant to be machined. The material properties are poor, as your finding out. It can be welded though...
I'd would not take that project on as it is destin to fail, but I offer a suggestion, use a good weldable aloy like 1018, and machine the thread onto that and weld it to the rebar.
up side is you can use your lathe with a bar feeder and have the lathe cut the bars to the right lenght. the time you save in load and unload may offset the cost for the steel bar, and the scrap your generating. not only that you can control the quality of the threads much better.
02/27/2008 1:25 PM
Labguy, its my understanding that rebar cannot be welded because of two things:
1. the steel alloy is pretty low quality, meaning that it is usually high carbon. (from all the carbon containing items in the scrap steel, like dead cats and car tires..) High carbon means that welding will be tricky and the whole bar may need to be heat treated to avoid cracking in the heat affected zone.
2. The mechanical properties of the rebar in part come from the deformation at relatively cool temperatures. We lose these properties if we heat the bar.
Kind of a endless loop...BUT: if we could weld to rebar, we could weld on commercially available threaded rod that some megaplant turns out by the ton!
It is my understanding that threading rebar is a common process for things like building anchors and the like. It just isn't pretty.
Jon.
02/27/2008 11:20 PM
I am sure rebar with high carbon content is weldable by using 312 stailess steel coated electrodes that would even weld dissimilar metals or unknown ferrous material to another. The only extra precaution is peening the weld to remove stress.
vshwn7@aol.com
Good Answers: 243
02/28/2008 10:45 AM
The lack of size consistency and out of roundness,
The lack of cold work prior to machining (the tool has to do all the lifting of the YS to The UTS to get the chip to break),
The lack of sulfur in the rebar, (No manganese sulfides to let the chip break; poor surface finish)
The likely out of straightness compared to a cold finished bar. (Thread and cutting workmanship issues)
The hard oxide scale on the OD. (tool life and surface finish)
All of these are why "buying Cheap material" (ie rebar) results in a more expensive product than purchasing a material optimized for the manufacturing process that also meets the engineering criteria for the application. (cold drawn bar)
this is a lesson that they will not soon forget.
There is no assurance that the Rebar in question is in fact high carbon, ASTM A615 does not limit carbon, only Phos. ASTM A6 is the controlling authority for chemistry, and gives many ranges for carbon, including .15 max; .15-.40, and so on. so there is no presumption that rebar is high carbon, or did I miss something? Most structural steel I've encountered along the way has been in the .30 range.
But I've been mostly in SBQ not structural market.
And while other posters have commented on Crushed toyotas, dead cats and the like, the fact is that after remelting, none of these "recycled items' would be identifiable in any way in the material. CAr tires are not intentionally added and only shreds of rubber and plastic (very small fraction by weight) would likely make it into the furnace...
Residual elements from higher alloy that got melted in would be identifiable, but they aren't the cause of the machining difficulty, they are a symptom of the melt shops scrap procurement policy.
Buy a cold drawn bar and watch you material cost component double, and your machining cost component get cut by a factor of 5 or 6. and quality improve.
Garbage in Garbage out...
milo
Good Answers: 230
02/28/2008 4:03 PM
Hello Milo
What else can I say.
Kind Regards....
Good Answers: 243
02/29/2008 9:38 AM
From someone with 57 good answers to their credit, this is great feedback!
Neon letters are cool.
Thanks.
milo
Good Answers: 230
02/29/2008 4:52 PM
Hello Milo
You can make neon signs yourself, just go to: http://www.glassgiant.com/make_pictures.php
Look for "Neon Sign maker".
After you make your sign (it's free, no malware) right click "SaveAs" to your own computer, modify if needed, then rename so you can find it easily.
Then, later, it may be used as needed.
Kind Regards....
Good Answers: 243
02/29/2008 7:24 PM
Thanks for this!
milo
Good Answers: 74
02/28/2008 5:42 PM
$ in $ out. Plus a reliable fuzz free product at any stage of handling. Your approach should be listened too. But then he could have 50 tons of the stuff stockpiled in the yard. Using before mentioned sleeves will do the job best it seems.
The Twain Has Met
03/03/2008 10:59 AM
It's pretty easy to give an answer to these questions that is all negative, that we are all idiots and there's only one better way to do the job--your way, using expensive materials chosen for threadability. Maybe we should be using leaded free cutting steel. I don't understand why its considered a good answer. Has no one noted that the end use is for rock bolts and therefore the deformed bar has another use--it needs to be grouted into the rock and the deformation aids in the retention?
The fact of the matter is that rebar is threaded all the time...we just haven't done it and are looking for POSITIVE suggestions on how to do it. In other words, shorten our learning curve.
There have been a few very interesting answers, such as swedging a threaded section onto the bar. It neatly gets around the issue of heat affecting the rebar's cold worked properties. Then a commercially available section of threaded rod could be attached. Some of the other suggestions about premachining, cutting speeds, tooling, cutting oils, and feedspeeds have also been helpful.
Jon.
Good Answers: 97
03/04/2008 1:11 AM
pre machining, won't actually effect the cold worked properties nor enhance the finished thread profile.
Not knowing what length of material I will yet recommend heating area of bar to be threaded and then pack in sand and slow cool to anneal or minimize the arbitrary conditions.
Coating on the dies will not help either because the machine doesn't go fast enough to take advantage of the coating. And then a coating will be rendered useless when die is sharpened.
I have threaded re-bar and no you will never get thread you would like but you can compensate by using heavier soft nuts (heavier = thicker)
If you choose to stub a easily thread-able metal onto the re-bar, as you weld heat the re-bar to cherry red 2"-3" of length at the weld area. This will normalize the weld and minimize irregularities.
Good Answers: 243
03/10/2008 2:20 PM
Hi sawmilleng.
I've been out of the country and just now checking my email.
Well, the detail about the rockbolts needing grouted was not obvious in the initial post, but with a more machinable material, grooves can be added econmically to create interstices to give the grout something to infiltrate and hold against. MAybe even deep knurls.
In the 1980's and early 1990's I was plant metallurgist for a little cold finish mill and we sold lots of cold finished steel bars to the guys who supplied the mining industry, some for roof bolts, some for tools, tool holders, and bits.
In my career I've seen many applications get bullied by the MBA's from what made engineering sense, to what makes MBA's cents.
The sense of exasperation in achieving the desired quality in the initial post painted a picture of a process not using an optimum material.
As this is an Engineering Forum < I took a process approach> to describe how the PROCESS Issues output was a reflection of the Quality of the KIV -MATERIAL INPUT ( Key input variables).
Had I known that REBAR is a must because of the deformations, I would have still tried to explain how the rebar properties affect the performance of your friends process.
Swaging a threaded sction onto a piece of rebar will require increased cost as now one of the pieces will need to be drilled out, the other likely reduced, unless it doesn't have to be same diameter as balance of piece, and the strength of the swage has to be validated. inorder to swage over say 10 % you will need to use a veryu low carbon bar, say 1008, in order to have sufficent % elongation to give you a significant swage. 1008 1008 will thread roll nicely, but drilling it out will be even less fun than threading rebar.
Sorry you felt no value in my response. I felt it appropriate and complete for the facts provided, especially as it was process focused.
Thanks for the feedback.
Milo
Good Answers: 137
02/27/2008 12:48 PM
I don't know much about manufacturing, but I assume threaded items like bolts and screws are made by stamping pieces of metal, hot enough to be soft, between 2 halves of a die, or something like that.
Since he has many thousands to do, is this an option? It would only take a few seconds to do each one, and you could have say 10 in a furnace warming up, putting another one in as one taken out. Might need to run an ordinary rotary die over to dress them up, but that would only be for finishing touches.
Cheers.......Codey
Good Answers: 97
03/04/2008 12:53 AM
You were doing great until after 'are made by' but great of you to take whack at it (:
02/27/2008 3:48 PM
Maybe grind a shallower approach angle on the chasers! It might help ease the agression on the front few teeth! But as said before, It's got bits of Lada in it!
Good Answers: 230
02/27/2008 10:22 PM
Hello sawmilleng
Some 40 years ago, we were in this same situation, for making rock-bolts.
We first used a lathe to trim up the workpiece, and make it more "round".
Then we used a "Rigid" screw-cutting machine, with 4 automatic jaws which did two cuts, first a light cut to get the basic thread form, then the jaws auto-opened, the cutters auto-backed off, and auto-closed for the final cut.
Rebar has changed in the last 40 years, but at least there is generally no WW2 battleship armourplate pieces in amongst the melted steel.
Cutting fluid we used was an evil-smelling high-sulphur cutting oil, if you got it on your clothes or skin, it was far worse than piggery effluent, and the aroma followed one around for several weeks.
It may be worthwhile, if the contract allows for it, to use the next size up rebar, machine the end to 1
Dependent on quantity and delivery timetable, it may be cheaper to discard your rebar pieces, and get the completed articles manufactured in China - it may be worth looking at if you don't mind doing that sort of thing.
Kind Regards....
United States - Member - New Member Popular Science - Weaponology - New Member
02/28/2008 12:32 AM
I liked Sparky's reply best. That dark sulfur smelling cutting oil is still the best in my opinion for cutting nasty steel. Your idea of getting TIN or AlTIN coated dies would probably increase the tool life but not likely improve the cut quality. I also agree that taking a cut on the lathe to make sure that the part is as round as possible and not oversize in places will certaainly help. If you can make some sort of an extension of the die holder that would have a roller guide or even a static guide to lead in front of the die you might end up with a a straighter thread. As for checking it, there is really no match for using a mating part, without getting very sophisticated and expensive with something like a laser probe from Renishaw.
Men are like steel, if they lose their temper they are worthless.
02/28/2008 12:54 AM
Look into rolling instead of cutting. You would probably have to turn the threaded section down in size first, but that would provide a circular cross-section for the rolls to work on. Along Codey's line, if they were heated, you might be able to use a rolling process to reduce the initial diameter, and a second to roll the threads.
02/28/2008 1:34 AM
One method you can use is to use a mechanical connector between a rebar and a threaded rod. These connectors are simple sleeves, one end of the rebar and one end of the threaded rod will be inserted halfway of the sleeve. Then the sleeve will be swaged/compressed.
This method is now widely used in splicing of rebars as an alternative to gas welding. There are now several companies offering the services/coupler/swaging machine, one of them is CCL Talaust under BHP Australia.
The technology is very simple, in fact we have already made a swaging machine ourselves, what you need are just dies sized for the rebar diameter with width of equal to bar diameter & a 100 ton hydraulic cylinder and hydraulic pump. For the cylinder/pump we used those high pressure type 10,000 psi from Enerpac or HiForce.
As for the sleeve we use Sch XXS A53 Pipe with inside diameter just enough to let the rebar in. Sleeve length is 6 times the bar diameter. The pipe sleeve should be normalized. Swage the sleeve with bars inside.
Destructive test results using UTM proved that failure will be in the bar and not at the sleeve. Occurence of sleeve or bar slipping - zero.
02/28/2008 7:12 AM
I am a machinst in a manf.setting we often thread rebar.
1 machine the high parts off , the two rails that run eather side
2 round or make pointed so die will start straight
3 flood with coolant, turn @10 fpm
this works for me building grizzles for rock crushers, thats what it sounds like you are building
Good Answers: 97
03/01/2008 2:40 PM
You beat me to the punch and sometimes you've got to work with what you've got.
02/28/2008 7:13 AM
as poor of machining quality that rebar is it might be an avanue to try or consider and that is drop forging if you have a good diemaker he could make the threads in the 2 halves of the die
the heat would normalise the metal and you wouldn't be losing much due to flash at this point you could just run a thread chase on the rods deprnding on the tolerances that are required
Beware the wrath of dragons for thou art crunchy and tast good with ketchup
Register to Reply 23 comments
Anonymous Poster (1); bwire (3); Codemaster (1); dkwarner (1); dragonbreath (1); garyceng (1); ky (1); Labyguy (1); Milo (4); Mr. Truman Brain (1); pantaz (1); rdavis (1); sawmilleng (2); Sparkstation (3); vishmayor (1)
You might be interested in: Rebar, Thread Gages, Thread Rolling Machines
