Previous in Forum: Power Supply Question   Next in Forum: current transformer multipliers
KIM certified ammeters and voltmeters
02/28/2008 9:30 AM
can any one help me to find out
the above mentioned 96*96 cut out
the above mentioned meters are for kazhakistan ..
they are demanding that meters on the panel should have this certification
can i know much if any one can sought it out
dennis
Re: KIM certified ammeters and voltmeters
02/28/2008 9:48 AM
96mm x 96mm is a standard panel opening size, for a panel-mounted instrument.
Does that come close?
Er, why does a panel hole need a certificate?
02/28/2008 10:28 AM
I am afraid you will have to let us know what the particular standard you are referring to means...
I've not heard of KIM certification before...
John.
02/28/2008 10:38 AM
kazhakistan importing standard
03/26/2008 4:23 AM
THKS FRDS
I CAME TO FIND THE METERS WITH THAT CERTIFICATION IN REVALCO DIGITAL 72*72 TYPE
THANKS FOR ALL
dennis
Register to Reply 4 comments
Anonymous Poster (1); Electroman (1); koshy.dennis (1); PWSlack (1)
