Previous in Forum: Pipe Inspections   Next in Forum: steam
pump alignment
02/28/2008 11:33 AM
acceptance values for radial and axial clearance for pumps
Re: pump alignment
02/28/2008 11:58 AM
.........can be found in the original equipment manufacturer's maintenance and repair manuals supplied with the pumps.
Re: pump alignment
03/02/2008 12:39 AM
Please check the tolerance of mechanical seal & coupling. These are the first to fail before the pump itself.
Remember, almost 90% of the failure analysis of the above are beyond the seal & coupling.
regards
jojie_oak
Re: pump alignment
03/30/2008 10:24 AM
Welcome to the forum.
We wish that you will contribute and learn from this forum.
Before we proceed to your question,here are few general tips to get the maximum out of this forum.
a) Please make your question as detailed as possible, more details you give the better answer you will get.
b) Avoid writing in CAPS as that is considered as shouting in this forum.
c) If any suggestion given by the member actually satisfies you, or does not solve your problem, keep that posted.
d) The members of this forum try their best to solve the problems and do have a very good command on the subject.
e) You will be surprised to see the amount of info, archives hold here..so do a search on here or at Mr Google, and in case you don't get anything you are welcome to post your query.
f) Ask one question at a time.
g) Do not use rude remarks and country/religion/ethnic background/poiltical innuendos, in your comments.
Now coming to your question try reading this article carefully.
http://www.machinediagnostics.com/pdf/Alignment/The%20Importance%20of%20Shaft%20Alignment%20(Turvac).pdf
Cheers.
He must be very ignorant as he answers all the questions he is asked. Voltaire
Register to Reply 3 comments
chaterpilar (1); jojie_oak (1); PWSlack (1)
