Previous in Forum: pump alignment   Next in Forum: 12000 m3 Api 650 storage tank
steam
02/28/2008 3:17 PM
I would like to be able to calculate the amount of dry steam I would need to produce to power a 2 stroke single cylinder 500cc at different rpm's up to a max of 10000 rpm, is there an equation or formula I could use? also, if possible temperature and pressure of the dry steam needed
Pathfinder Tags: dry steam calculations
Good Answers: 114
Re: steam
02/29/2008 12:12 AM
So you're trying to make a steam engine?
usually you push the piston each direction, for a single cylinder, every revolution will take 1000cc's of steam.
you will need to know the size of the piston, to calculate the pressure requirements & output torque.
Converting a multi cylinder, would be an easier task.
Good Answers: 137
Re: steam
02/29/2008 4:10 AM
Is this a steam engine, and you just want to know amount steam needed, or is it a 2-stroke IC engine you hope to run using steam? Ref to 2 stroke single cylinder 500cc sounds like the latter, but you can't do that, leastways not without some mods, as the valve gear is very different.
Steam engines are always 2 stroke and as Garthh says, usually double-acting, in which case 1000cc of steam per rev at actual steam conditions, assuming the inlet valve is open throughout the stroke. If you know the P & T of the steam, you can work out the mass flow. But the P & T required depend on the power you want from the engine.
Cheers........Codey
Location: Earth. England/America -the birthplace of the C. S. A. - anywhere I imagine -home.
Re: steam
03/01/2008 2:27 AM
Check with Lynx steam engine about conversion details. Yes, it will take some modifications, especially if you want some efficiency. E-mail beesidemeusa@yahoo.co.uk and ask about steam. Has done some research on the Net.
No technology is so obsolete that it won't work. A stone knife still can kill you as dead as a laser.
Re: steam
03/30/2008 7:06 PM
Register to Reply 4 comments
Codemaster (1); Dweezle (1); Garthh (1); Taganan (1)
