Previous in Forum: steam   Next in Forum: Aluminum Extrusion Cutting M/C-NOISE Problem
11 comments
12000 m3 Api 650 storage tank
02/28/2008 6:37 PM
Could any one provide latest plant capital costing for a 12000m3 APi 650 steel storage tank (at atmospheric pressure) ?
Re: 12000 m3 Api 650 storage tank
02/29/2008 6:20 AM
hi friend
u what like u write msn mdogrul@hotmail.com i wait
02/29/2008 2:54 PM
Would you determine your place and situation.(work specification...ex.)
augurozkan@hotmail.com
03/02/2008 5:52 PM
Thanks for replying. The proposed tank is located 1.5 km from the coast line, within 2 km radius of major industrial zone where transport and handling are not a problem. The ground is rated suitable without piling and the liquid stored is inflammable with specific desity(0.95) but mildly corrosive. It has a floating roof and ideally with 30m diameter.Material use: ASTM A283 and 3 coats of epoxy.
Price is purely as cost bench mark for comparsion. Don't overly concern.
03/04/2008 5:03 PM
Dear Lawrence Js,
Pre-manufacturing of tank (acording to the project)1700-1900$/ton(except erection)delivery from manufacturing shop.
Flooting roof 70-100 Euro/m2
Epoxy coating 3 coats(total dry thickness 350-450 mikrons);sand blasting,sigma coating material(for corrosion) and labors include 30$/m2
Real result could be calculated after project has been seen and conditions have been cleared.
good lucks,
Good Answers: 19
03/15/2008 6:49 AM
You are good. Congrats. joining in. After Mr.Halim now we've you.
03/15/2008 10:16 AM
Yes ducon, welcome CR4 new member auozkan
In addition to the cost predetermined by auozkan, I'd like you to take into consideration the cost of :
a. Cathodic protection system
b. Fire fighting system (cooling water and foam)
c. Floating roof and sealing system
d. Isolating and breathing valves
e. Instruments, controls and metering system
f. Internal epoxy coating
g. Civil work
03/20/2008 5:15 PM
12000 m³ CONE ROOF COST DETAILS ( for one tank - Ex Work )
TOTAL QUANTITYUNITUNIT PRICETOTAL MAT PRICEFABRICATION PRICEERECTION PRICEGRAND TOTAL
A. ENGINEERING
A
€ 20.000,00
B. STEEL MATERIAL
B
BOTTOMANNULAR PLATES12,717ton€ 575,00€ 7.312,28€ 635,85€ 0,00€ 7.948,13
BACKING PLATES0,1ton€ 575,00€ 57,50€ 5,00€ 0,00€ 62,50
CENTER PLATES58,498ton€ 575,00€ 33.636,35€ 2.924,90€ 0,00€ 36.561,25
SHELLSHELL PLATES93,682ton€ 575,00€ 53.867,15€ 28.104,60€ 0,00€ 81.971,75
WIND GIRDER8,149ton€ 575,00€ 4.685,68€ 2.444,70€ 0,00€ 7.130,38
TOP ANGLE1,032ton€ 575,00€ 593,40€ 309,60€ 0,00€ 903,00
ROOFPANTOON PLATES81,488ton€ 575,00€ 46.855,60€ 26.076,16€ 0,00€ 72.931,76
CENTER PLATES29,673ton€ 575,00€ 17.061,98€ 1.483,65€ 0,00€ 18.545,63
ROOF SUPPORTS9,436ton€ 575,00€ 5.425,70€ 3.302,60€ 0,00€ 8.728,30
STRUCTURAL STEELSEXTERNAL STAIRWAY1,436ton€ 575,00€ 825,70€ 502,60€ 0,00€ 1.328,30
TOP PLATFORM0,882ton€ 575,00€ 507,15€ 308,70€ 0,00€ 815,85
TOP LADDER0,334ton€ 575,00€ 192,05€ 116,90€ 0,00€ 308,95
C. ACCESSORIES
C
AT BOTTOMBOTTOM DRAIN1sets€ 1.326,00€ 1.326,00€ 0,00€ 0,00€ 1.326,00
DRAW-OFF SUMP2sets€ 240,00€ 480,00€ 0,00€ 0,00€ 480,00
AT SHELLMANHOLES2sets€ 1.022,00€ 2.044,00€ 0,00€ 0,00€ 2.044,00
FLUSH TYPE CLEANOUT2sets€ 2.250,00€ 4.500,00€ 0,00€ 0,00€ 4.500,00
LEV.INDICATOR SUPPORT0,28ton€ 1.365,00€ 382,20€ 0,00€ 0,00€ 382,20
NOZZLE FOR ROOF DRAIN1sets€ 56,00€ 56,00€ 0,00€ 0,00€ 56,00
NOZZLE FOR INLET PRODUCT2sets€ 240,00€ 480,00€ 0,00€ 0,00€ 480,00
NOZZLE FOR OUTLET PRODUCT2sets€ 285,00€ 570,00€ 0,00€ 0,00€ 570,00
NOZZLE FOR RECIRC1sets€ 56,00€ 56,00€ 0,00€ 0,00€ 56,00
SPARES NOZZLES2sets€ 56,00€ 112,00€ 0,00€ 0,00€ 112,00
DRAW-OFF NOZZLES2sets€ 45,00€ 90,00€ 0,00€ 0,00€ 90,00
SAMPLING NOZZLES5sets€ 85,00€ 425,00€ 0,00€ 0,00€ 425,00
TEMPERATURE NOZZLES2sets€ 40,00€ 80,00€ 0,00€ 0,00€ 80,00
LEVEL SWITCH NOZZLES2sets€ 55,00€ 110,00€ 0,00€ 0,00€ 110,00
AT ROOFMANHOLES2sets€ 565,00€ 1.130,00€ 0,00€ 0,00€ 1.130,00
NOZZLE FOR GAUGE HATCH1sets€ 95,00€ 95,00€ 0,00€ 0,00€ 95,00
AUT. BREATHER VALVE NOZZLES6sets€ 115,00€ 690,00€ 0,00€ 0,00€ 690,00
RIM VENT NOZZLES2sets€ 56,00€ 112,00€ 0,00€ 0,00€ 112,00
PANTOON MANHOLES18sets€ 400,00€ 7.200,00€ 0,00€ 0,00€ 7.200,00
ROOF DRAIN SUMP1sets€ 1.000,00€ 1.000,00€ 0,00€ 0,00€ 1.000,00
V/P BREATHER VALVE6pcs€ 1.400,00€ 8.400,00€ 0,00€ 0,00€ 8.400,00
GAUGE HATCH1pcs€ 375,00€ 375,00€ 0,00€ 0,00€ 375,00
MECH.LEVEL INDICATOR1sets€ 5.680,00€ 5.680,00€ 0,00€ 0,00€ 5.680,00
AUT.LEVEL INDICATOR1sets€ 11.360,00€ 11.360,00€ 0,00€ 0,00€ 11.360,00
LEVEL SWITCH2pcs€ 115,00€ 230,00€ 0,00€ 0,00€ 230,00
RIM VENTS2pcs€ 400,00€ 800,00€ 0,00€ 0,00€ 800,00
THERMOMETER2pcs€ 56,00€ 112,00€ 0,00€ 0,00€ 112,00
FLAME ARRESTOR1pcs€ 2.850,00€ 2.850,00€ 0,00€ 0,00€ 2.850,00
GUIDE POLE1sets€ 2.850,00€ 2.850,00€ 0,00€ 0,00€ 2.850,00
ROLLING LADDER3,5ton€ 1.500,00€ 5.250,00€ 0,00€ 0,00€ 5.250,00
D. FLOATING ROOF SEALING SYSTEM
D
1comple€ 46.900,00€ 46.900,00€ 0,00€ 0,00€ 46.900,00
E. FLOATING ROOF DRAINING SYSTEM
E
1comple€ 46.000,00€ 46.000,00€ 0,00€ 0,00€ 46.000,00
F. FIRE FIGHTING
F
FOAM SYSTEM1comple€ 21.500,00€ 21.500,00€ 0,00€ 0,00€ 21.500,00
WATER COOLING SYSTEM1comple€ 9.600,00€ 9.600,00€ 0,00€ 0,00€ 9.600,00
RIM SEAL FIRE PROTECTION1comple€ 3.500,00€ 3.500,00€ 0,00€ 0,00€ 3.500,00
G. PAINTING
G
1comple€ 14.500,00€ 14.500,00€ 0,00€ 0,00€ 14.500,00
H. ELECTRICAL WORKS
H
LIGHTING1comple€ 2.850,00€ 2.850,00€ 0,00€ 0,00€ 2.850,00
EARTHING1comple€ 1.136,00€ 1.136,00€ 0,00€ 0,00€ 1.136,00
CATHOTIC PROTECTION1comple€ 23.900,00€ 23.900,00€ 0,00€ 0,00€ 23.900,00
J. TRANSPORT TO ..............
J
TOTAL EX-WORK
€ 485.966,99
03/21/2008 2:51 AM
Good work
03/01/2008 6:19 PM
Please do your homework.
03/02/2008 11:17 AM
Dear Sir
it's mean that you requirement for somebody to supply or design for you?
If you request to prefabrication or installation of tank.We are pleased to offer for supply all you need.
Thank you
Addhaphol
atasinter@gmail.com
Good Answers: 19
03/15/2008 10:39 AM
Aw! come off it. Here go see a website of Ducon's Associate:
www.zishanengineers.com
Sorry I never wanted to advertise this or my web site.
Abdel Halim Galala (3); Anonymous Poster (2); auozkan (3); ducon (2); lawrence Js (1)
