My home was built in 1986 and is located in Sarasota County Fl. It is a ground level slab monolithic footing. It was constructed with a 6 mill poly. vapor barrier, #6 welded wire mesh, under slab copper pipe plumbing. Exterior walls are concrete block stucco. The property is in a subdivision which has a man made lake which sits approx. 150' to the rear of the home. Soil from the lake was used to raise the properties prior to construction. It is of the maral base. (very dense shell, hard to dig) They did bring in about 5 loads of fill for grading above for the slab. The water elevation of the lake is approx. 4' below the slab surface. All grading around the home is away from the slab at least 4" below slab surface. The roof has complete gutters and downspouts leading away from the home. Back in August of 2005, we noticed a under slab plumbing pipe break under the slab which forced water up through one of the areas in the floor where the plumbing supply came through the slab. It flooded about 500sf of floor area with about 1" of water before I woke up and shut off the main. The under slab pipe break was located and fixed. Of course we could not match the ceramic tile which was in place. After being faced with replacing our complete kitchen and approx. 1600sf. of flooring we had the complete house re-plumbed over head with cp-vc. NO EXISTING COPPER WATER SUPPLY LINES ARE ACTIVE UNDER THE SLAB. The construction was completed and we went with a 20" x 20" porcelain tile. The project was completed in January of 2006. In March of 2006 we started noticing moisture coming up in the grout joints in the room of the original leak. We had the tile company come out and pull a few tiles and the slab and was saturated with standing water under the porcelain tile. Note, the slab moisture test prior to installing the tile was OK, using a standard industry moisture meter. Within the next few months the moisture migrated through the complete tiled area except a sitting room and a bedroom area which is 4" below grade of the remaining home slab. The rooms are separated by a 16" footing, and no copper lines are in this area. Two different engineering firms have been out and both agree that the original leak is the problem. They checked the elevations, water table, pool for leaks, and the original cp-vc drain lines and new over head cp-vc supply lines.
My problem is that no one can figure out how to dry out the slab. Core drilling was done which showed the soil is very damp under the slab. The tile has been removed through the house except the sitting area and bedroom which were not affected. The kitchen and bath cabinets are left in place sitting on top of the tile. Do to the expense of removal and replacement of these the insurance company said it should be ok. We had a company come it with 9 air movers and 10 dehumidifiers for 10 days which brought the air temperature inside to over 100 degrees. The moisture tests were getting lower but not fast enough for the insurance company so the decided to pull the units. They have since rethought the process and have brought in another company to try a different approach. They have 20 air movers and only 3 large dehumidifiers. We are trying to keep the temp. down this time running the air conditioning. It has something with the grain size of the vapor which is to be removed.
I have also checked into having the slab sealed with a penetrating sealer manufactured by Euclid, which is supposed to change the matrix of the concrete itself making it much more dense and then sealing the surface with a cement base water proofing material. Will this cause the water to be forced under the cabinets and up the walls which cannot be treated?
What recommendation would you make on drying out the soil and the slab? Or would you recommend another approach?
We had air quality tests done and they came back with elevated mold, but that is another problem.
Your help would be greatly appreciated as you can see, I am about at my wits end.
Sincerely, rgouge31
