Previous in Forum: Plumbing Problems in Florida: How to Dry a Slab?   Next in Forum: Profibus VFD Slowing Down, Then Speeding Up?
13 comments
Free or Low-Cost PLC Training Courses?
03/03/2008 11:35 PM
I am looking to get back into Maintenance and every interview I go on they want plc experience I have very Little of it I'm more of a relay logic type of old fart but am fast to learn and PC friendly is ther any free or very low cost PLC training courses out ther or does any one have some thing I mite be able to learn from fairly easy?
Thanks in advance Ray
Say what you do,And do what you say
Re: PLC Training HELP!!!
03/04/2008 3:06 AM
Have a look at this thread. It's got lots of examples of cheap logic controllers - they don't have all the capabilities of a full-blown PLC, but will give you a good start. Many of them have free downloadable software & manuals (with example programs). The software can often be used in a simulation mode - so you can create and test the program without even having the controller.
Enjoy!
03/04/2008 4:07 AM
Back in the 1980s, Allen Bradley sold some PLC training courses at every level from their training centre in Sutton Coldfield, just outside Birmingham. Do they still run?
03/04/2008 4:16 AM
Don't know - but if they do (under the Rockwell influence) they'll almost certainly cost several teeth, if not a limb or two!
Re: Free or Low-Cost PLC Training Courses?
03/04/2008 10:27 PM
Thanks for the Help I down loaded the program software and will play with it to see if I can remember how to climb
its bean awhile since I used a Ladder logically that is
Thanks again for the help and if any more I will drain brain and refill if I half to
03/04/2008 10:46 PM
Someone has posted tutorials of the Edexcel Higher PLC subject here
http://www.freestudy.co.uk/ncplc2007.htm
03/05/2008 6:40 AM
in general all PlC communicate with PC with the help of communication cable or with compatible hardware conversion.
it required by directional software for communication with each other, or PLC manufacturer software.
as all address and hardware are manufacturer proprietary item.
you can config all ports as you like with I/o , analog of digital what ever available with the plc also you can add on additional if required depend upon flexibility and expansion of PLC manufacturer.
what you want to do please tell in brief may i help you.
nayanelectronics@yahoo.co.in
03/05/2008 8:43 AM
Hello old FART: modernize they say, compromise I say.
I don't know how much help this will be to you, but this link should take you to where you can download software for a programmable logic relay.
http://www.telemecanique.com/REF/Newsconsole.nsf/TemplateUS/6478D72586C941C0C125710600539F5C/?OpenDocument
PLR and a PLC are basically the same thing, the PLR is a stripped-down version. Many companies give away their software for the PLR's. This software is fully functional, can be programmed and run in simulation mode on your computer.
I'm a ladder logic man myself, this software offers you two programming options. Ladder logic and function block logic, so if you need to practice your function block programming (as I do) you can do it to your hearts content.
The software also contains a pretty good online help file, good luck.
Hope this helps you.
Signed the RELIC
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore all progress depends on the unreasonable man" George Shaw
03/11/2008 12:21 AM
Thanks to all of you
I am Trying to get out of auto-mechanics and back in to maintenance My true love and every one wants PLC experience? it looks like there is not much to it a few sensors and a PC based controller line voltages should be in schematics and LED's emit or not s/w open or closed program time to fast or to slow simple
Thanks for all the help and Links
03/13/2008 9:48 PM
You can use a simulator instead of real hardware. I am presently trying to learn PLC programming and I use the decently priced stuff from here. http://www.thelearningpit.com/
Having used relay logic I am having a hard time getting used to the idea that the logic doesn't match the inputs.
You can download a free 800 page book on the subject here. http://www.eod.gvsu.edu/~jackh/books/plcs/ I find it helpful. It starts with the basics.
06/08/2013 2:12 AM
We Provide the low Cost PLC Training. If You want You can contact us.
PLC Training
12/14/2014 2:30 PM
hey ,,,some of the free plc simulators are available..with that you can learn yourself..logixpro is a good one..free plc programming softwrae
Engineering Fields - Control Engineering - Control Engineering Technical Fields - Education - Industrial Training Engineering Fields - Manufacturing Engineering - Manufacturing Training Engineering Fields - Electrical Engineering - Electrical engineering Training Engineering Fields - Instrumentation Engineering - Instrumentation Engineering United States - Member - New Member Engineering Fields - Energy Engineering - Become part of the larger group, change your world.
03/27/2016 4:05 PM
Now days there is a lot more to learning just ladder logic if you actually want to do the safely, reliable, using best practices outlined at PLC Training Org. But we all have to start somewhere, for basics see http://bin95.com/allen-bradley-plc-programming.htm
To better get you well on your way to dealing with PLCs is the real world, consider Koldwater's PLC Technician bundle.
(I know this was an old post, but current readers may need the updated info. So I hope this helps.)
AB PLC Training onsite, On-Line, training software and more. BIN95.com
03/27/2016 8:27 PM
Reported as Advertising.
Register to Reply 13 comments
Anonymous Poster (1); BIN95 (1); CEngWannabe (1); jarunmagnet (1); JohnDG (3); PWSlack (1); RAYSLENN (2); sugina (1); vipuldravid (1); YWROADRUNNER (1)
