Previous in Forum: Maintaining Flowline Instruments in Flow Stations   Next in Forum: Selecting Cables to Transmit 4-20mA Signals
Selecting Pressure Gauges: Criteria to Consider?
03/05/2008 3:07 AM
Dear sir/madam,
may i have anyone advise about the selection of the pressure gauges type(bellows,diaphgram/bourdon)? what criteria should i consider?
Thank you very much.
5
Re: selection of pressure gauge type
03/05/2008 3:49 AM
A principal concern is the compatibility between the fluids at the temperatures and pressures, and the wetted materials. It would be no good, for example, fitting a bronze gauge to a line containing hot sulphuric acid.
Many organisations have Standards to be followed. Pharmaceutical primary manufacture, for example, might specify diaphragm gauges on all primary bulk manufacturing lines. Steam is never attached to a diaphragm gauge, and the gauge is nearly always attached to a line via a 'pigtail' condensate loop and a gauge isolating cock. Gauges attached to the outlet of centrifugal pumps will normally have a 'snubber', a device that minimises and smooths-out the effects of vibration caused by turbulence generated by the pump. Others might insist on glycerine-filled gauges. Some applications might insist on blow-outs on the back off the gauge so the case doesn't rupture catastrophically if the sensing element leaks.
Check the organisation's local instrumentation standards and follow them. They will have been developed on the basis of best local practice. If these don't exist or are unclear, then copy similar installations that work, having first discussed the pros and cons with the local Maintenance Technician in each case so that pitfalls can be avoided.
Malaysia - Member - Master
03/11/2008 11:04 PM
Here i have problems where my Pressure Gauge which is attached to the Centrifrugal Pump,where the pointer always stuck at certain bar.Is this cause of high turbulence pressure cause of the pump or else?Do I need to used the snubber?
Elect & Instr
03/21/2008 2:55 PM
Yes. I also advocate using a needle valve in conjunction with gauges. Just open the valve to read and then close. This also takes a lot of wear and tear off the gauge.
Wonder if you are getting spikes? There is a gauge made with two pointers. One pointer stays at the highest pressure recorded until reset.
Peace be upon you.
Register to Reply 3 comments
PWSlack (1); Skelley (1); Yasser (1)
You might be interested in: Pressure Gauges, Accordion Bellows, Metal Bellows
