Previous in Forum: Selecting Pressure Gauges: Criteria to Consider?   Next in Forum: Distance Measurement
Selecting Cables to Transmit 4-20mA Signals
03/05/2008 5:11 AM
Dear Sir,
For Power lines we can select the cable based load current & voltage drop along the line, but What could be the criteria of selecting cross section of incrementation cables to transmit 4 -20mA DC signals and digital signals(on/off status) over a distance of 500 m?
Re: Selecting cables to transmit 4 -20mA signals
03/05/2008 5:30 AM
Mechanical strength of the conductors is the primary consideration.
0.75mm2 is typical.
Good Answers: 59
Re: Selecting Cables to Transmit 4-20mA Signals
03/05/2008 10:07 PM
I join PWSlack and add a few. You can calculate the resistance, and most likely will find not to be a problem. the twisted pair will need to be shielded, If you do not want large noise contamination. And keep it away from power cables.
03/06/2008 4:09 AM
Quite. Useful additional points.
03/06/2008 4:25 AM
Hi Asitha,
usually you have a configuration like that:
Example:
Given UB = 24V DC
Usource = 2V (thats for UCE, e.g.)
Usignal = 10V (depends on your following input like ADC etc.,
is the maximum voltage at maximum current of 20mA)
Then RL = 10V / 20mA = 500 Ohm
UB = Imax * (Rlead1 + Rlead2) + Usignal + Usource
Rlead = (UB - Usignal - Usource) / (2 * 20mA)
(with Rlead = Rlead1 = Rlead2)
So each of the two leads may have a voltage drop of max. 6Volts and you can
evaluate your required mm².
Having a distance of several hundred meters a twisted shielded wire is recommended.
Regards Uwe
The sum of intelligence on earth is a constant. And the population grows and grows and .....
Hobbies - DIY Welding - New Member Popular Science - Weaponology - New Member
03/06/2008 5:43 AM
In the telecom world we guarrenty the customer 23ma to his phone set. To do this we suply -50Vdc at the Centeral Office so this means we can have a maximum of 1500 ohms in the cable pair if we allow for 400 ohms in the CO wiring, 200 ohms in the phone set and 35 ohms for the house wiring.
03/06/2008 3:25 PM
Why not do it without wires, check out www.remotecontroltech.com.
Register to Reply 6 comments
Anonymous Poster (1); leveles (1); PWSlack (2); Redman46 (1); uweka (1)
