Previous in Forum: 12dc pond solar pump continous use   Next in Forum: Project Planning
Fuel consumption
03/08/2008 10:59 PM
What do you think is a reasonable estimated Heat Rate ( in kCal/kWh) of a 200 MW steam turbine generator and fuel compsumption in (US$/ton). Calorific Value of the coal is 5000 kcal/kg??
Re: Fuel consumption
03/10/2008 4:25 AM
Assuming the over all efficiency of the steam turbine , boiler and the alternator as 25 % and taking 1 kw as 860 kw,
The fuel required for 200 Mw is appx 137931 kg/hr.
If heat recovery is considered , then you may increase the efficiency to higher value and work out accordingly.
Good Answers: 19
03/11/2008 9:52 PM
Sir, please register yourself so that when in need I/we can communicate with you.
You seem to be highly technical and it will be a sheer waste of energy if you do not share your experiences .
You might be interested in: Fuel Cells, Fuel Testers, Fuels and Fuel Products
