Hello all
Having a bit of an argument at work as to wether a 3 phase rotation meter will rotate on a split phase system.
Basically it has the windings at 180 degrees and i say due to the difference in angle (i.e 180) the meter will turn and i have tried it....it works but everyone else says otherwise.
Their reason is that the "2" phases happen at the same time in "time" and will be seen as only one phase.
I know there is no real reason to know the rotation as each one follows the other but it is one of those arguments that just needs sorting if you know what i mean.
Thankyou for any input.
